Getting rid of check valves, restoring MAP sensor
Old Aug 6, 2003 | 03:49 AM
JustAnotherHonda's Avatar
Default Getting rid of check valves, restoring MAP sensor
This is for a b16. Did anything sit between the map sensor and the throttle body? I'm hoping it was a washer or o-ring of some kind 'cause I can hear a lot of hissing activity around the sensor when the car is running, and the idle fluctuates (which is what I'd expect if the MAP sensor is leaky).
Does anyone have a part number for the sealing thing that I'm missing? Or is there a suitable generic (non-OEM) replacement?
Thanks!
Old Aug 6, 2003 | 04:00 AM
Zero2Sixty's Avatar
Default Re: Getting rid of check valves, restoring MAP sensor (JustAnotherHonda)
its just a rubber o-ring you can probly go to petboys or a hardwear store in your area and get one.
skata89
Dec 31, 2007 12:59 PM
tgreaves
Dec 3, 2003 12:08 PM
comptechgsr2000
May 8, 2002 03:53 PM
