Engine Swap Need Help with Fitting Turbo.....
Old Aug 6, 2003 | 04:34 PM
StickersDontAddHP!'s Avatar
Default Engine Swap Need Help with Fitting Turbo.....
I need some help. I've got a 92 Civic Si Hatchback right now. Even with the turbo it still lacks the speed I'm craving. So I'm thinking about getting a b18c5 which I have all ready to order once I figure out a few more things. The onlyquestion I could have is with the displacement that the b18c5 has would I need to do work to the head gasket and the pistons so I don't fry my engine when I give it boost? I've been told I would but I'm not 100% sure. The current turbo I have is off a thunderbird coupe but the turbo I would most likely get for the b18c5 would be the t3/t4 hybrid..... Do you know if I'll run into any big problems???
Old Aug 8, 2003 | 08:12 AM
VTcivic
Guest
Posts: n/a
when you say displacement, you mean compression??? id say youd need to run lower compression pistons. what size turbo you lookin at?
Old Aug 8, 2003 | 03:34 PM
Default Re: (VTcivic)
T3/T4 Hybrid....herm, lest you have a better Idea.
Old Aug 8, 2003 | 03:51 PM
ghettocrxsi's Avatar
Default Re: (StickersDontAddHP!)
When he is talking about size. he means Trim size. Wheel size. How much hp do u want to make.
Look around a bit and you will find all the info you need. Honda-tech has a plethora of information on anything forced induction.
Old Aug 10, 2003 | 10:33 AM
VTcivic
Guest
Posts: n/a
yes, ^^ thats exactly what im talking about. what trim and wheel size, not what KIND of turbo. t3/t4 is a TYPE of turbo, not the size of it. do a search and look up turbo sizes and such.
Hector Conde
Aug 28, 2015 02:55 AM
Glove
Dec 10, 2009 07:24 AM
black0hatch
Jul 10, 2009 06:47 PM
slowcrxsib16
Sep 26, 2007 06:00 AM
iamthemouse
Aug 18, 2003 11:07 AM
