fuel question
Old Jul 17, 2011 | 02:43 PM
sh!ft's Avatar
Who the fack changed my title?!
Default fuel question
which route would you rather take?
option 1: stock fuel tank, eliminated internal fuel pump/lines, sump welded on, external lines/pump
option 2: rci(or similar) fuel cell, external pump/lines, placed in original location of oem tank, modded oem filler neck to accommodate fill location of cell.
having an issue on deciding which one to use. id like to keep the stock tank just for the added weight and the ease of not worrying about being too light in the rear end when going fast. this is on an ef hatch as well.
Old Jul 17, 2011 | 11:07 PM
sh!ft's Avatar
Default Re: fuel question
any one??
Old Jul 18, 2011 | 09:06 PM
Terrible One's Avatar
power goals?
Old Jul 18, 2011 | 10:48 PM
sh!ft's Avatar
dd/450hp/15psi
Old Jul 19, 2011 | 01:56 AM
DelSolMarine's Avatar
to answer your question... option 1 for a dd...
i mean your going to dd a car with like 5 gallons of gas to carry around?
If your power goal is for 450whp then you do not need to go through that much trouble... people have run single walbro intank fuel pumps and made over 500whp... you could get a dw301 or one of the new 340lph fuel pumps and have enough fuel for close to 600whp...
Old Jul 19, 2011 | 04:28 AM
kyden's Avatar
stock everything with an aftermarket in-tank.
Old Jul 19, 2011 | 09:31 AM
Dual pumps/sump tank is overkill for ed 450hp
Old Jul 19, 2011 | 09:54 AM
sh!ft's Avatar
edit: ONE pump you mean, never wanted 2 pumps
Old Jul 19, 2011 | 10:00 AM
SovXietday's Avatar
Why make it so complicated? Drop in a Walbro and enjoy the car. You don't need anything more than that for your power goals.
Old Jul 19, 2011 | 10:06 AM
sh!ft's Avatar
does it make a difference that im using a borg warner s360??
Old Jul 19, 2011 | 10:13 AM
SovXietday's Avatar
Not if your power goals are only 450whp. My walbro is supporting me no problem at 402 on E85, and that's on a Dseries.
If you were going for 600whp, I'd say go with the Aeromotive intank and have fun.
IMO, I'd only run a fuel cell when you want to take the car off the road for good. They're such a PITA.
Maple50175
Apr 11, 2009 07:26 AM
vtekstorm
Apr 13, 2004 04:05 PM
Hispeed
Jul 13, 2001 09:16 AM
