Leaking oil
Old Jul 1, 2011 | 03:26 PM
spoolinvtec54's Avatar
Default Leaking oil
I have a turbo b16 and driving it for the first time with a built head. I noticed it's smoking from under the hood and out the exhaust, I saw that there was oil on the compressor wheel. The turbo is a turbonetics turbo, could it be blown oil seals on the turbo?
Old Jul 1, 2011 | 04:03 PM
LocoJoe's Avatar
Default Re: Leaking oil
Probably blown front & rear seals. Running a restrictor on the oil feed line?
Old Jul 1, 2011 | 04:36 PM
Ya I am the turbo not that old. Idk why it smoking under the hood.
Old Jul 1, 2011 | 05:25 PM
LocoJoe's Avatar
If its leaking out of the rear seal, oil is coming out of the turbine into the exhaust housing. That maybe where the smoke comes from
Old Jul 2, 2011 | 02:59 AM
I'm just stumped on it leaking out the compressor housing inlet.
Old Jul 2, 2011 | 07:54 AM
rich7777's Avatar
Post a picture up of your oil return
Old Jul 3, 2011 | 05:55 AM
http://i1237.photobucket.com/albums/...g?t=1309698626
you can see the oil coming out of the compressor housing.
Old Jul 3, 2011 | 05:56 AM
Old Jul 3, 2011 | 06:39 AM
LocoJoe's Avatar
You running a restrictor?
Old Jul 3, 2011 | 07:11 AM
Ya I am.
Old Jul 3, 2011 | 07:23 AM
TheShodan's Avatar
Moderator
That return line at the fitting into the oil pan might be a problem.
Since the turbo is a turbonetics, they'll repair that, more than likely without charge.
Old Jul 3, 2011 | 07:30 AM
Ill have to change the intercooler piping around so return line is more straight into the oil pan. Or just get different angle fitting.
Old Jul 3, 2011 | 09:57 AM
LocoJoe's Avatar
I think TheShodan means the bung on the oil pan is angled a little down and since oil drops by gravity not pressure, i guess it piles up there up to the turbine and explodes into the seals
Old Jul 3, 2011 | 12:05 PM
Ya I got u. I'm look at getting like a 45 degree fitting or a 90. See if that works.
Old Jul 3, 2011 | 12:15 PM
rich7777's Avatar
Use 2x 45° or a straight from the turbo going to a 45° at the sump. Don't use 90°. Try and make it work with that.
Old Jul 3, 2011 | 01:34 PM
I decided to buy new oil pan and going to tap It in diferent spot so it will work better.
zach1288
Mar 18, 2009 03:54 PM
Cyber ITR
Feb 4, 2007 06:44 AM
Slammd Sol
Nov 7, 2004 10:00 AM
done
Jul 27, 2004 08:10 AM
