Distributor question...
Old Jun 26, 2011 | 08:35 PM
swisscheese32's Avatar
Default Distributor question...
My distributor went out in my ls/vtec turbo del sol. This is my first turbo'd car and was wondering if there is anything special i have to do when i put it in compared to a naturally aspirated car?
Old Jun 26, 2011 | 09:06 PM
MR.johnson's Avatar
Default Re: Distributor question...
No. Get a Vtec dizzy or chop an ear off a ls one.
Old Jun 26, 2011 | 10:48 PM
civickiller's Avatar
How did u make your na dizzy ready for fi in the first place?
Old Jun 27, 2011 | 08:05 AM
i bought a vtec one
Old Jun 27, 2011 | 09:55 AM
wantboost's Avatar
Who is Mr Robot?
ummmmmmmmmmmmmmmmmmm. yea
Old Jun 27, 2011 | 10:07 AM
Turbo-LS's Avatar
i didnt know there was a difference between an N/A dizzy and a FI dizzy lolololol
You dont do anything to it, you install it per the hanes manual, depending on yoru engine management is how you hold the ignition tables at 16 degrees and sync the distributor with the engine management then its good to go.
Old Jun 27, 2011 | 01:12 PM
Alright, i pulled out the old distributor, and compared it to the new one, they look exactly the same but the wiring is different. there is the same number of wires but the connectors are different. I then noticed the old one has been cut and put back together, is taht because my block is from a early 90's teg and my head is from a 99si? so you have to switch the connectors????
Old Jun 27, 2011 | 02:11 PM
also how do you test a distributor to make sure its actually bad?>
Old Jun 27, 2011 | 03:23 PM
What does the harnesses dizzy plugs look like ?
Y did u think it was bad in the first place?
Old Jun 27, 2011 | 07:29 PM
my car won't start and the harness on the new one is one clip and the old one is two seperate clips
Old Jun 28, 2011 | 03:35 AM
Turbo-LS's Avatar
Single cluips is OBD2, two clip is OBD1. if you know what yoru doing you can make a conversion clips your self or you can just buy one
Freemananana
Oct 22, 2015 10:57 AM
JAYDmManny1331
Sep 18, 2009 08:01 AM
Fastwhip
Apr 11, 2006 12:58 PM
I 8 1 U 8 1 2
Sep 18, 2003 02:03 PM
b20ek
Jul 15, 2003 05:02 PM
