Sandwhich Plate with Oil Cooler/Rel. Kit
Currently I am running a Glowshift oil filter sandwich plate to feed oil to my turbo, and plug in sensors for oil temp/pressure.
I do not have an oil cooler yet but I am looking into purchasing one soon.
Now with most oil coolers come the filter relocation kit with the feed plate for the cooler.
I'm wondering if I can run my current sandwich plate for the turbo feed etc... in conjunction with the relocation kit and feed the cooler?
Thanks!
Thanks!
Retired Moderator
Re: Sandwhich Plate with Oil Cooler/Rel. Kit
If it were me, Id tee off the oil pressure switxh for the feed and sensor, then use the plate for the oil cooler.
Heres a kit and directions:
http://www.xenocron.com/remote-oil-p...70db84f45bc1d0
Heres oil coolers on the cheap:
http://www.votionspeed.com/servlet/t...ers/Categories
When you say oil pressure switch are you meaning the sending unit?
My only concern with that is that the lines are 3/16" and the fittings for the cooler are 1/2". In that situation would you use adapters?
Also if I'm using two ports on the sandwich plate for the cooler wont the pressures equalize and restrict any flow?
I appreciate your help!
hndacord02
05-30-2010 07:23 AM
creechrr
01-02-2007 02:04 PM
Black R
06-27-2004 05:54 PM
DamonBoost
06-16-2002 04:24 PM
