New build won't start.
Old Jul 8, 2011 | 03:08 PM
csmith21's Avatar
Default New build won't start.
This is my second motor I've built and I'm running out of ideas as to why it won't start.
B18C block 81.5mm
B18B crank
B18B forged eagle rods
Wiseco 6542M815 Pistons 81.5mm
Stock B16 head
First off, my motor is hard to turn with the head on. Turning by hand is impossible, even with the spark plugs/cams out. So I first checked my timing. Timing is dead on and there are no bent valves, or valves hitting the pistons. It will turn with my starter(brand new), but it is fairly slow. It is getting spark, fuel, and it has compression. It's pumping oil just fine into the head and I'm not getting any CELs. It is also shooting out exhaust as I turn it over. I just can't seem to understand why the motor is so hard to turn over. I figured it would be hard, seeing as it is fresh, but I've never had this big of a problem before. It seems that if I figure that out, I might be able to get it started. Any ideas? My battery is fully charged btw.
Old Jul 8, 2011 | 03:32 PM
civickiller's Avatar
Default Re: New build won't start.
not enough cranking fuel?
Old Jul 8, 2011 | 03:44 PM
csmith21's Avatar
I've primed it about 20 times lol. And it has a half a tank of gas. I'll keep trying though.
Old Jul 9, 2011 | 07:46 AM
RACEPAK's Avatar
maby you have a very tight clearance on your bearings?
EDIT:
what are youe r clearances?
Old Jul 9, 2011 | 10:47 AM
rich7777's Avatar
Did you torque the main down and check the crank spin's freely when assembling ? Your crank maybe not be straight (and yes it can happen if its not stored correctly). Somethings not right anyway. I'd start pulling the main caps off and inspecting the bearing if i was you.
Old Jul 9, 2011 | 11:43 AM
da_dude's Avatar
Check your valve lash.
Old Jul 10, 2011 | 05:56 PM
csmith21's Avatar
It rotated freely all the way until it sat on the stand for three months.
Valve lash was way off. I set it and the exhaust is 0.008" and intake 0.006". It fires and acts like it wants to run and then just stops.
Old Jul 10, 2011 | 06:15 PM
DDTECH's Avatar
Lets verify.
You got spark and fuel? How do you know?? Stick a screw driver in the spark plug wire and hold it to the body, make sure you can see the spark.. pull the rail, make sure ALL injectors fire on a crank over, it'll be good to have a friend or two hold the rail and injectors, otherwise they'll fly out lol..
Valve lash would effect compression and therefore effect starting, lets just go down the basics..
Also check all your fuses under the hood and dash. I've had many cars not start because a fuse was blown and was failed to get checked for..
Why is your motor so hard to turn, what are you clearances.. bearings and piston clearances... regardless of who assembled the motor, a good rule of thumb is to rotate the crank whenever something is tighten down.. every time a main cap, or a rod cap is tighten down the motor should spin freely.. really weird..
Sitting on a stand for 3 months, is it possible some "rust" may have formed?
Old Jul 14, 2011 | 06:51 AM
csmith21's Avatar
I finally got it started. Apparently on the start up map, I had selected the wrong map sensor somehow. Switched it to the stock one, fired on up.
Old Jul 14, 2011 | 06:58 AM
rich7777's Avatar
Good stuff ! I bet that was a nice feeling ! !
Old Jul 14, 2011 | 07:56 AM
ShanghaiOC's Avatar
Oh man, I had that same problem for a day. It was frustrating checking out all of your install! When I finally gave up, I just asked my tuner for a reflash for ***** & giggles. Same problem showed up and sure enough, we had the wrong MAP chosen as well.
Old Jul 14, 2011 | 04:52 PM
csmith21's Avatar
It's always a good feeling when you get stuff that you built to work. Thanks man
Yeah, I'm glad I decided to look back at the map.
Old Jul 15, 2011 | 03:23 AM
Fc_v8's Avatar
Thats good to hear that you got it fired up, so how does it run? It sounds weird that you couldnt spin the crank by hand...
Old Jul 15, 2011 | 07:15 AM
csmith21's Avatar
It runs well and I can rotate it by hand now with a little effort. I guess it just needed some starting action first lol.
Old Jul 15, 2011 | 08:01 AM
sanman000719's Avatar
time to hit the valley for some 1/8th action
ill be down some time in oct to give mine a go at it down there as well
Old Jul 15, 2011 | 08:48 AM
csmith21's Avatar
What city you live in brotha?
csmith21
Jul 15, 2011 09:50 PM
01typer1124
Mar 16, 2009 06:49 AM
Ignitecivic
15
Oct 24, 2007 08:58 PM
turbohb91
Apr 10, 2005 11:45 PM
