what could be causing my ignition to cut out?
Old Jul 12, 2011 | 09:54 AM
EG6 Love's Avatar
Default what could be causing my ignition to cut out?
I have a OBD1 turbo GSR engine. while tuning, i was able to do 3rd gear pulls to redline with no problems while i was running 6,7,8 and all the way to 12 PSI. once we raised the boost by 4 pounds up to 16 PSI, i was unable to make a full pull because my tuner said i was getting "ignition cut" around 7000 rpm or so. I am running a MSD cap and rotor, MSD blaster SS coil and new OE honda wires.
NGK BKR7E at .033" is my current spark plug.
any help would be appreciated. Thanks.
Old Jul 12, 2011 | 12:01 PM
Terrible One's Avatar
Default Re: what could be causing my ignition to cut out?
have you tried reducing your spark plug gap?
Old Jul 12, 2011 | 02:51 PM
EG6 Love's Avatar
i havnt tried anything yet since im just starting to dig into this problem. i will check and report the gap shortly
Old Jul 12, 2011 | 03:00 PM
jdm inc's Avatar
what spark plug are you running? heat range wise?
Old Jul 12, 2011 | 03:21 PM
DDTECH's Avatar
You "should" be on Heat range 8.. and your gap should "start" @ .025..lower if you must.
16psi shouldn't blow out a gap @ .025.
Old Jul 12, 2011 | 03:30 PM
EsotericImage's Avatar
Retired Moderator
^^ shouldnt blow out at .030 either!
Old Jul 12, 2011 | 07:41 PM
blackeg's Avatar
isnt an 8 range a little colder than necessary for a 16 psi gsr motor? ive been using the bkr7e's for about half a decade now never had an issue.
might be worth a try to put the oem parts back in the distributor. i know ive seen many oem wires turn a faded dark greenish color on the outside in the past but they have had many more miles than you have on yours
Old Jul 12, 2011 | 08:47 PM
7 = up to 500hp
8 = up to 600hp
9 = up to 800hp
10 = up to 1000hp
Old Jul 12, 2011 | 09:17 PM
EG6 Love's Avatar
i am running a NGK BKR7E with a gap of .033"
Old Jul 13, 2011 | 10:42 AM
EG6 Love's Avatar
above a gap of .025"-.030" has been mentioned. does that mean that my .033" gap could cause the ignition to cut out under full load?
Old Jul 13, 2011 | 11:46 AM
DDTECH's Avatar
Originally Posted by Terrible One
7 = up to 500hp
8 = up to 600hp
9 = up to 800hp
10 = up to 1000hp
all cars are different.. i've seen turbo cars only making 300 want 8's..its all dependent on the setup.
Old Jul 13, 2011 | 11:47 AM
Retired Moderator
Nope..
Theres boosted cobalts running .045 gap and they dont blow out. so im sure your safe.
Personally, i would run an OE ignition as ive heard bad things with MSD for street cars. If your car was blowing 450 WHP+ i could def see the MSD set up. Im putting my $$ on the MSD causing your pain.
Old Jul 13, 2011 | 04:03 PM
EG6 Love's Avatar
well im just shy of 400 whp right now and im looking to make about 500-550. sooo.... thats why i opted for an MSD setup
Old Jul 13, 2011 | 10:46 PM
Nooch's Avatar
Check with whatever is easier to swap (change) first, like lowering your gap to .030 at least. See if it still blowing out then.
Old Jul 14, 2011 | 04:02 AM
EG6 Love's Avatar
i would normally do that but it doesnt do it now since I'm at 12 psi. It did it when the boost was turned up during the tuning process. I'm getting ready for a trip to ill garage for a new tune and I don't want to pay all the money to get my car put to them and then not be able to make hardly anymore power.
Old Aug 23, 2011 | 07:08 AM
jdecks23's Avatar
What was the conclusion?? Having a similar issue.
Old Sep 2, 2011 | 04:22 PM
EG6 Love's Avatar
I have yet to figure this issue out. I have compiled more detailed data and made a new thread regaurding this issue.
Old Sep 2, 2011 | 04:51 PM
viper_boy403's Avatar
your OEM ignition setup will be fine at that level. I would never put an MSD ignition on a Honda, I've only ever seen them cause problems
Old Sep 2, 2011 | 06:04 PM
SAXON's Avatar
Check your grounds
Old Sep 2, 2011 | 11:51 PM
SovXietday's Avatar
That's relevant...
I bet if you drop the gap to .025, you will have no issues. May also need to switch spark plugs out for new ones, misfires tend to destroy them.
Old Sep 3, 2011 | 10:56 AM
DDTECH's Avatar
I've told you how to solve your problem...Gap it down.
Old Sep 3, 2011 | 07:38 PM
10sec4door's Avatar
by cutting out do you mean ignition/car turning off. I am having some problems too. Car drives fine but under load at about 7k rpm car turns off. I havnt been able to data log with my tuner yet just trying to get an idea of what could be going on. Im running NGK 7s
Old Sep 4, 2011 | 01:27 PM
EG6 Love's Avatar
ignition, the engine rpms bounce like a 2 step
Old Sep 4, 2011 | 01:41 PM
Retired Moderator
if ALL MOTOR told you to do something, then listen to him. he knows whats up
Old Sep 4, 2011 | 02:26 PM
DDTECH's Avatar
At first you thought it a "misfire"..now you think its a 2step??
If you have ign cut, chosen on your EMS, the ign cut is violent and will make the rpm gauge jump and what not and "feel" like a two step. If your tuner doesn't know which one is happening, i'd take it to another tuner.
