Small turbo on B18C1
Old Jun 24, 2011 | 02:05 PM
alperx's Avatar
Default Small turbo on B18C1
Hi
I have a b18c1 with 9:1 cr wiseco pistons.
What if I put a small size turbo (like a Garrett T25) ?
and use it with a pressure like 10 psi.
is it safe even at high RPMS ? (egt temp)
When the car doesnt produce power at high rpms
because of the small size of the turbo, is it risky in any way ?
Old Jun 24, 2011 | 02:23 PM
SLIM NOTHING's Avatar
Default Re: Small turbo on B18C1
a stock b18c1 can handle a good deal of power they have seen up as high as 550.. with a great tune from a great tuner and upgrade the fuel system and your safe. stick with redline if you are using stock valvesprings. so im sure your lil turbo wont hurt it at all. just do it right.
Old Jun 24, 2011 | 07:09 PM
TheShodan's Avatar
Moderator
You'll bascially blow hot air into the combustion chamber and waste your time due the efficiency of cylinder head. Throw that turbo in the trash that the DSM guy it to you for.
Old Jun 25, 2011 | 12:28 AM
lol true never thought about the lil air it pushes
Old Jun 25, 2011 | 05:41 AM
EsotericImage's Avatar
Retired Moderator
not too many people use a T25 anymore.. Why not look into a garrett super 60? Just a little larger, but quick spool regardless.
Old Jun 25, 2011 | 12:00 PM
JDMTiger4's Avatar
Just drop a gt35r turbo into it and call it a day.
Old Jun 25, 2011 | 06:40 PM
Schister66's Avatar
Man U FTW
Exactly
If you're looking for a quick-spooling, little turbo, I would consider the GT28rs as well as the T3 Super 60...a T3/T04e 50 trim wouldnt be bad either. Any of these should put you over 300whp and have very quick spool.
Old Jun 26, 2011 | 05:31 AM
4cylfiend's Avatar
A garrett 50 trim, super 60, or even a precision 5857 are all good entry level turbos that will workout for you much better than a t25.
CanadianEF9
Feb 10, 2011 03:42 PM
DC4R27
Oct 6, 2007 07:34 PM
Westrock2000
Nov 27, 2006 03:02 PM
mattduskater
18
Oct 9, 2003 04:09 PM
