V-band downpipe doesn't flex enough at flex joint, ideas?
Old Jul 9, 2011 | 05:30 AM
sflemon's Avatar
Default V-band downpipe doesn't flex enough at flex joint, ideas?
I've got a car that runs a setup with about 450-500whp and lots of traction help.
The motor does flex some even with very nice uprated motor mounts.
I have a flexpipe/bellows in my downpipe about 3 feet down from the turbo.
Constantly the downpipe will rub/tap the firewall either due to not enough flex or poor design of my custom downpipe or poor assembly of it to the rest of the exhaust.
What happens is it loosens the V band right at the turbo and causes a huge exhaust leak. Then I have to take an hour cussing/swearing and reconnect all that crap.
I'm not beyond running the downpipe out the hood or the passenger fender.
Ideas?
Old Jul 9, 2011 | 10:52 AM
turbohatch96y7's Avatar
Default Re: V-band downpipe doesn't flex enough at flex joint, ideas?
Ummmmm get the down pipe fixed..
Cut and weld
You could rent a welder at home depot
Old Jul 9, 2011 | 04:08 PM
pwebb0207's Avatar
have you inspected the car on a lift?
Old Jul 9, 2011 | 09:20 PM
pcguy760's Avatar
Maybe you should have your downpipe re-done - if its hitting the firewall, someone messed up the angles of the pipe when welding it ....
9TechNine9
Mar 27, 2018 09:35 AM
NZXTInerTia
Welding / Fabrication
12
May 29, 2013 07:11 PM
PINKS
Jan 1, 2006 11:14 AM
opto_isolator
Jul 31, 2004 10:14 PM
B17aTrbo
Nov 16, 2001 08:53 PM
