Boost barely hitting 10psi?
Old Jun 25, 2011 | 11:03 AM
$amGD3's Avatar
Swaggylicious
Default Boost barely hitting 10psi?
Ok so, about 3-4 days ago I noticed that in WOT I could only get 7-8psi, I've had the car set to do 12-13 with the Prosport MBC for months now.
I looked around under the hood to look for a vacuum line leak or any boost leak from the couplers, all seem well. The charge piping that goes into the turbo, has a flat spot but it should still seal properly when clamped on ( i think)
While I was diagnosing that, I saw that my DP is only on by one bolt and all of the other has sheared off. So I had to take out the manifold/turbo and used an extractor to get the broken bit out. After all of that is done, I put everything back together and drove the car and now the car is getting barely 10psi
I used a compressor and a makeshift boost leak tester to check it under pressure. The compressor cover where it meets the turbo looks like it was leaking a bit, as well as the bolt for the throttle cable( where the spring is on the tb)
What do you guys think it can be?
Is my MBC bad? I've tried adjusting it and nothing happens
Would that little flat spot/ovalling on the charge pipe has this much effect?
Old Jun 25, 2011 | 11:41 AM
Gunmetal_B20_Hatch's Avatar
Default Re: Boost barely hitting 10psi?
when does it make 10psi? at redline?
what is your wastegate pressure?
leaking BOV?
Old Jun 25, 2011 | 01:22 PM
$amGD3's Avatar
Swaggylicious
not redline,just at wot at around 5-6k when i usually see full boost
i believe i have a 7lb spring in there
we checked the bov when we did the boost leak test and it was fine. Unless theres another way to check it?
Old Jun 25, 2011 | 08:04 PM
$amGD3's Avatar
Swaggylicious
Bump?
Old Jun 25, 2011 | 08:17 PM
Schister66's Avatar
Man U FTW
The issue with the charge piping wouldnt cause this issue. This is going to be one of a few things:
1. Bad boost controller
2. Leaky wastegate
3. Boost leak
4. Turbo is shot and can't spin fast enough to make sufficient boost
5. Bad signal to the wastegate/MBC
Old Jun 25, 2011 | 09:17 PM
racebum's Avatar
agree with post above
and
remove the mbc and see what happens. if it goes to gate pressure perfectly and runs right i would see what happens with another mbc, it sounds suspect and would be a good place to go after you look over the fittings
Old Jun 26, 2011 | 06:57 PM
$amGD3's Avatar
Swaggylicious
2. Leaky wastegate
3. Boost leak
I'll run the turbo straight to the WG and see if it hits spring pressure tomorrow
How would I check for a leaky wastegate?
Also, how can i check if the turbo is shot? It's a brand new bought 5431B and is maybe 4000 miles old. Zero shaft play, no oil anywhere.
What do you mean by signal to the wg/mbc?
Old Jun 27, 2011 | 11:54 AM
$amGD3's Avatar
Swaggylicious
bump
Old Jun 27, 2011 | 04:24 PM
racebum's Avatar
means the vacuum
SpoolnG2
Aug 15, 2009 08:16 AM
playahwitgame
Jul 9, 2006 09:25 PM
zseeanz
Jun 4, 2005 09:44 PM
mugenhatch92
Apr 25, 2005 07:32 PM
Cashflo
Aug 15, 2002 03:27 AM
