Question for turbo EF Full-Race radiator users
I'm planning a B-series turbo build for my EE wagon and wanted to know if anyone had overheating issues using the Full-Race radiator?
My car will be a street driven/weekend car with several trips to the drag strip but not daily driven. My goal is 400-450hp. I already have the Full-Race radiator and traction bar. My current setup is N/A LSVTEC and it did start to overheat once on a really hot day(90 degrees) after doing a burnout at he track. At that time I was using a cheapy 10" puller slim fan which may have contributed to the problem. Since then I replaced that fan with a 12" puller fan from SPAL and had an aluminum shroud made. Have not had a problem since then but I know a turbo setup will generate considerably more heat.
My dilemma is that I don't want to start building a turbo setup around this radiator only to find out it may have overheating issues. Advice and suggestions preferably from people with personal experience using this radiator are greatly appreciated. Thanks.
Re: Question for turbo EF Full-Race radiator users
The radiator itself doesnt really make that big of a difference, but the main thing is to get a good, quality fan. I have an eBay CXRacing radiator and anice 12" fan(no shroud) and have never had any overheating problems. I have a 170* thermostat on my sleeved 2.0L engine. Fans are set to turn on at 180* and temp usually hovers around 185-190.
I have an ek, but I cut metal away to fit a 13" spal its rated at 1750cfm setup as a pusher it was the best I could find.
Thanks for the input guys. There is a notable difference in size/surface area between an EG half size radiator and a EF Full-Race. I cannot fit a 13" SPAL fan on this radiator. This is were my concern lies since I would either have to cut into the cars lower radiator support and/or lean the radiator back in order to fit the EG half size. I would prefer not to do this if the Full-Race radiator is sufficient for my needs.
Any other Full-Race radiator users out there who would like to comment?
My car will get hot after a pass at the track, but I also have a Precision 750hp intercooler blocking most of the airflow to the radiator. How big of an intercooler are you planning on using? You might want to consider ways of getting fresh airflow to the radiator instead of heated intercooler air.
Never had an issue with that rad in my brothers ef. B-series, with a 3.5" thick intercooler in front of the radiator.
I have the traction bar/rad set up in my turbo crx with the same power you're looking for. I have a pretty crappy slim fan and my car only starts to overheat in traffic on hot days. If I had a nicer/stronger fan I don't think i would have any problems.
I have a 500HP set up and do have over heating issues. I'm personally a little dissapointed in the full-race radiator. But the bay in a CRX is pretty tight. I've driven my car without the bumper and no overheating issues though, so its air flow for sure. I have a FAL fan and it's on the whole time.
Mine did try to get hot as well after a pass or driving for a period of time then coming to a stop, IC was blocking most of the air to radiator so I cut a 2x10inch size hole on the hood in front of radiator and it stoped the issue.
I dont have any pics as I am in process of converting to jdm front end, however I am convinced that the gap in between the hood and filler will serve the same purpose as hole in usdm hood I cut as far as getting more air to the radiator. I will also prop the hood to better help the cooling.
Shroud it for the fan. Very important, the rad is pretty small and covered well by the intercooler, unless you leave a path for air to get to the rad. Make sure the air has no way to go when it gets through the IC except through the rad, don't just rely on the fan.
