Witch BOV ?? help .
Old Jul 8, 2011 | 10:28 PM
lsv_ 973's Avatar
Icon2 Witch BOV ?? help .
hey just needed some info kinda lost .. i was lookin to buy a new bov an wasnt sure on witch to get .. i have a turbo b18b1 on 8psi . i wanna get the tial 50mm bov but wasnt sure witch psi to get .. im gunna turn up the boost on my setup to 12psi ..
Old Jul 10, 2011 | 03:41 AM
EsotericImage's Avatar
Retired Moderator
Default Re: Witch BOV ?? help .
research.
turbosmart
greddy
tial
HKS
are all decent
Old Jul 10, 2011 | 05:21 AM
Schister66's Avatar
Man U FTW
The Tial 50mm will work fine for your setup, but there are other options available. If you get the Tial, be sure to get the right spring in it. There is a chart on Tial's website which shows a table of intake manifold vacuum and relates it to a certain spring. Be sure to check you're getting the correct spring before ordering. I believe most Hondas are around -19in/Hg at idle if that helps...
Old Jul 10, 2011 | 06:20 AM
TheShodan's Avatar
Moderator
As much as I love the TiALs, in this case a GReddy RS or RZ would be a better, simpler choice, simply because at such a lower boost pressure, he won't have to worry about which spring he needs to change in or out. For such needs, its the simplicity that makes this one so much more appealing, as long as he doesn't cheapen out and get a knock off version
Old Jul 10, 2011 | 11:37 AM
Schister66's Avatar
Man U FTW
The simpler the better
Old Jul 11, 2011 | 05:17 AM
Retired Moderator
Hmm, i wouldve recommended the HKS as it works great with all boost ranges..
but then again, I havent had any experience with the greddy ones..
didder
Aug 26, 2008 05:50 PM
JLHDOHC
Aug 2, 2006 05:43 PM
Vtec92Civic
Dec 18, 2004 11:22 AM
AF-b16a1
Aug 11, 2004 11:30 PM
gpomp
Feb 16, 2004 11:47 PM
