shaft play?
Old Jul 6, 2011 | 10:23 PM
hellaflushdb2's Avatar
Default shaft play?
ok so i have a garrett m24 ar48 turbo and the shaft slightly moves side to side without hitting sides? do i need a rebuild? i found this on the garrett website idk if mines dual ball bearing or if this applys to me. any help would be much appreciated.
How much shaft play should my dual ball bearing turbo have?
The Garrett full ball-bearing turbo is designed to have clearance between the bearing cartridge and center housing for hydrodynamic damping in addition to the internal clearances of the bearing cartridge itself. Hydrodynamic damping uses the incompressible properties of a liquid (oil in this case) and the space around the bearing cartridge to dampen the shaft motion of the rotating assembly. When the turbo is new, or has not operated for a long period of time allowing most of the oil to drain out, the rotating assembly will move more in the radial direction than a typical journal-bearing turbo because there is no oil in the center housing. This condition is normal. As long as the shaft wheel spins freely and the wheels don't contact their respective housings, the assembly will function properly.
b20beast83
Feb 5, 2009 11:06 AM
GdmLaz
May 1, 2006 09:49 AM
GdmLaz
Apr 30, 2006 03:39 PM
Flamenco-T
Sep 28, 2004 08:58 AM
John
Oct 23, 2001 07:16 PM
