Boosted 35R K24/K20 Arp Torque spec help!
Whats up HT. I tried using the search forums tool for this and im in need of the answer asap. I didnt find anything under the search..My question is what is the recommendation or even the standard torque specs for arp head studs for a boosted setup of this nature.I have an account under alldata's website and they have a different method of tourqe then what i have available by degree's, they say 29 ft/lbs then 90degrees in sequence and then again additional 90. that torque wrench i do not aquire and will be using a digital snap on...so if anyone can give any insight on how many actual ft/lbs of torque this head to our k24/k20 build needs would be greatly appreciated. Car will be running 20 psi and im sure that may have a factor in how many ft/lbs. Thanks Guys Adam, High Compression Automotive.
1sicef9
05-06-2010 03:58 PM
