te05h mitsubishi turbo questions...???
Old 06-26-2011, 10:32 AM
ekblackcoupe's Avatar
Default te05h mitsubishi turbo questions...???
i installed a mitsubishi turbo, but i am stumped on how to clock my turbo. the oil drain line right now comes out at just under a 90 degree angle, and i beleive this is why it smoked on startup and sometimes when i shut off the car. the feed line is horizontal also, just not sure how to clock it being an internal wastegate set up.
also i was thinking that my feed line might be too big. its 1/4 inch stainless braided, should i run a reducer in it? could this be why its smoking?
i searched and found nothing at all, but if someone has a link, id MUCH appreciate it!
Old 06-26-2011, 10:58 AM
viper_boy403's Avatar
Default Re: te05h mitsubishi turbo questions...???
As long as nothing is attached to the center housing, you can clock the center wherever you want. You just need to keep the compressor and turbine housings in the same spot in relation to each other
Old 06-26-2011, 11:02 AM
welfarepc's Avatar
its a pain in the *** with those turbos
get some reallly big snap ring pliers it will be easier.
Old 06-26-2011, 12:02 PM
i tried the big snap ring plier thing...bent everything i have. that ****er is on there tight!
Lewy. Dee Ayy
05-15-2012 06:03 PM
BigZeke5
10-16-2008 06:20 AM
Del$olB16A3
05-31-2005 04:16 PM
GReddy SI
08-29-2004 09:20 AM
wade
03-21-2004 06:34 PM
Quick Reply: te05h mitsubishi turbo questions...???
