cant go past 4500 rpm
Ok so heres my setup i have a 97 accord f22b1 60 trim turbo, 440 injectors, p28 with a obd2 to obd1 step down harness so i cant read check engine codes, aem fpr and fuel rail
this is my problem before i bought the aem fpr i had an ebay fpr and i was redline and now that i have aem one i cant there both set at the same pressure i dont know whats wrong any advise will helpu
Re: cant go past 4500 rpm
No cel and ive talked to one of the guys at c&m they said the reason why i cant read codes with a scanner is because obd2 cars have somethings obd1 dont so it cant read it
You need to jump the connector under passenger side dash with a paper clip.
A light blue connector I believe then your cel will flash the codes
so what happen when you hit 4500? Limiter?
b18c-ivic_gsR
09-28-2004 04:45 PM
