Question about engine limitations vs psi
Old Jul 6, 2011 | 08:17 PM
vtak2nr's Avatar
Default Question about engine limitations vs psi
Ok, lets say X engine can hold 300whp on stock internals
Lets say Big turbo can deliver 250whp on 6psi
Lets say Small turbo can deliver 250whp on 12 psi
Does it all equal the same thing? (i would be just as safe running 12 psi on a small turbo as i would 6psi on a bigger)
Whenever I read a thread on how much boost a certain motor can take, people always say X amount of psi. But psi depending on turbo equals cfm so wtf
by the way....for a more direct example, I'm refering to an SiRII motor
Old Jul 7, 2011 | 04:39 AM
kyden's Avatar
Default Re: Question about engine limitations vs psi
people that say you can only run x psi should just be ignored. whatever it takes to get to the goal is what you run.
Old Jul 7, 2011 | 05:38 AM
Spawne32's Avatar
in the theoretical sense yes it should all be the same, rods and pistons are such are rated in horsepower because they are designed to handle the power of the explosion of air and gas during combustion, so 250hp is 250hp regardless of how you get there.
Old Jul 7, 2011 | 09:36 AM
vtak2nr's Avatar
perfect thanks =]
THEhomelessONE
Jan 9, 2019 09:24 PM
J337_UNIT
Sep 23, 2009 05:49 PM
93egSLEEPER
Mar 29, 2009 12:42 AM
Panoply
Dec 6, 2006 09:39 PM
DXRacer
Feb 21, 2003 07:04 AM
