EGT Question
Old Jun 27, 2011 | 12:43 AM
alperx's Avatar
Default EGT Question
I have a LS/VTEC.
I have a full 3" exhaust system and a ramhorn manifold.
If I connect a Garrett T28 turbo (from a 200sx) with an external wastegate,
do you it will be OK even at high rpms at 10 psi ?
Or is it risky to use it in case of high EGTs.
Old Jun 27, 2011 | 06:42 AM
civickiller's Avatar
Default Re: EGT Question
I don't see why it wouldn't be ok, lots of people use t28's
Old Jun 27, 2011 | 06:48 AM
alperx's Avatar
maybe on higher pressures, because of backpressure..
Old Jun 27, 2011 | 07:22 AM
You might just have early spool with it no top end, good dd turbo
but I've never used a t28 so idk exact boost range
Old Jun 27, 2011 | 07:30 AM
Garrett731's Avatar
you will have no problems on such a small turbo, even at high RPM's.
just make sure the tune on the motor is good.
92VXeg
Sep 18, 2008 10:06 PM
93supercoupe
Jan 23, 2006 09:43 AM
rough_draft
Jul 2, 2005 01:35 PM
redrex
Nov 5, 2003 07:55 PM
