Increasing mid range on a b16..
Old Aug 4, 2004 | 03:02 PM
Boostage's Avatar
Default Increasing mid range on a b16..
Would a 84mm bore give a b16 mid range tq like a b18c? I know that 3mm cant compensate for the much larger stroke of a b18c. but with CTR intake cam GSR exhaust cam and a t3/sc61 it should be very noticeable right?
Im still contemplating buying a gsr shortblock and building it or, resleeving my b16 to 84mm. my goal is to have a 400hp+ car with very good low end response here is a break down of what I have:
Full weight 94 civic ex coupe
stock bore b16a2
eagle rods, JE pistons 8.8:1 c/r
780cc precision injectors
rev springs and retainers
both JG edlebrock intake and aebs typhoon (not sure which one I will use)
sc61-stage 5 wheel .69 a/r
AEM EMS
LS tranny with quaife differential (complements of Earl )
So whats the best option? keep my b16 and go 84mm or get a b18c?
Old Aug 4, 2004 | 04:29 PM
Boostage's Avatar
Default Re: Increasing mid range on a b16.. (Boostage)
ttt
Old Aug 4, 2004 | 04:42 PM
Jared's Avatar
with a b16 stroke you'll never have the torque or midrange of a 1.8, but the bigger bore will help. also, ditch the LS trans and get a b16 trans.
Old Aug 4, 2004 | 04:43 PM
Jared's Avatar
Default Re: Increasing mid range on a b16.. (Jared)
and i would go with the Edelbrock intake over the AEBS.
Old Aug 4, 2004 | 06:30 PM
Boostage's Avatar
selling the trans is not an option. I have a $900 quaife in it. plus I overpaid for the trans because it was legitamate. which is rare in my aera.
Old Aug 5, 2004 | 06:37 AM
99B16Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">selling the trans is not an option. I have a $900 quaife in it. plus I overpaid for the trans because it was legitamate. which is rare in my aera.</TD></TR></TABLE>
well thats one of your major problems there. the combination of a b16 and an LS tranny is probably one of the worst possible and will make your car extremely sluggish
84mm B16
LS tranny
PS u can always pull the quaiffe out and put it into a b16 tranny(wont fit GSR/ITR)
Old Aug 5, 2004 | 06:52 AM
Oyvind Ryeng's Avatar
More midrange = Higher static compression, a small-*** turbo and a really good tune. Stroking also helps the midrange.
Old Aug 5, 2004 | 08:26 AM
Boostage's Avatar
Default Re: Increasing mid range on a b16.. (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">
84mm B16
LS tranny
PS u can always pull the quaiffe out and put it into a b16 tranny(wont fit GSR/ITR) </TD></TR></TABLE>
so get the b18c or build 84mm b16 and more boost?
Old Aug 5, 2004 | 09:55 AM
White Smoke's Avatar
i my honda
Global Mod
Well if you are sleeving either one than get the b18
If you already have the pistons you may have a problem
If you only can afford to build the b16 OR buy a gsr bottom....
SLEEVE THAT BITCH
Old Aug 6, 2004 | 04:56 PM
Boostage's Avatar
Default Re: Increasing mid range on a b16.. (si2die4)
I think I am just going to go 84mm on the b16
gunsnbam
Dec 12, 2008 03:44 PM
sohcvtec706
Mar 4, 2007 02:01 PM
jdm_AE86
Nov 6, 2006 09:52 PM
af97civic
Dec 2, 2003 04:31 PM
