PLX wideband install help
Old Aug 5, 2004 | 11:37 PM
Stewie's Avatar
Default PLX wideband install help
I want to use plx wb sensor in place of my stock o2 sensor. I just wanted to make sure that this diagram is correct.
Is that resistor connected in the diagram correctly? One end of the resistor is tapped into the heater ground wire and the other end to the heater power wire?
Old Aug 6, 2004 | 01:40 AM
eddyboy's Avatar
Default Re: PLX wideband install help (Stewie)
That diagram is correct, the same one i used when installing mine
alghafat424
Nov 25, 2004 06:49 PM
t0eKnEe
Apr 1, 2004 02:32 PM
