PROBLEM WITH TIAL BOV!!!
Old Aug 3, 2004 | 01:31 PM
si_blues's Avatar
Default PROBLEM WITH TIAL BOV!!!
I was wondering if anyone else was running a tial bov and if you had any trouble with it not blowing off. If anyone is looking to get rid of a type s for good price let me know!
Old Aug 3, 2004 | 01:32 PM
DA9-T's Avatar
Default Re: PROBLEM WITH TIAL BOV!!! (si_blues)
Which lbs spring is in the BOV? Did you try giving it its own seperate vacuum line?
Old Aug 3, 2004 | 01:43 PM
si_blues's Avatar
Default Re: PROBLEM WITH TIAL BOV!!! (DA9-T)
No its not even on the car yet the car is still being built. I have a buddy that has the same bov on a eclipse gsx and his wouldnt blow off until 26 lbs. We tried to crack it by hand and its impossible, we had to put it on a press to even think of cracking it open. Also I really want type s anyway, Im trying to figure it all out before the flange is welded
Old Aug 3, 2004 | 01:52 PM
Casey's Avatar
i private messaged u chris
Old Aug 3, 2004 | 02:57 PM
Blurex's Avatar
i have a tial and i have the same problem it wont open until its above 11psi or so....i tried to press it buy hand and could not...but it does work, just not a lower psi levels..
Old Aug 3, 2004 | 03:08 PM
DaX's Avatar
DaX
Loved
Community Favorite
Before I installed mine, I was worried I had the high PSI one also, so I took the BOV apart to check the spring color. I have a silver spring. It's a mother to push open by hand...almost can't be done.
After installing it and feeding it boost/vacuum from a vacuum manifold, it works flawlessly...I can even hear it opening at slight vacuum [7-0" Hg] on shifts. I love the way it sounds and performs, and I don't think there's a better BOV on the market.
Old Aug 3, 2004 | 03:37 PM
Casey's Avatar
Default Re: (DaX)
oh yeah chris, ive got a tial bov too, so if you want we can meet up and see if yours has the same stiffness as mine, i know for a fact mine is a 7psi spring
Old Aug 3, 2004 | 04:42 PM
si_blues's Avatar
Default Re: (Casey)
I dont have mine here its at the shop casey. I went ahead and let phil do my motor because of my lack of knowledge, id rather it run instead of sit and look pretty
Old Aug 3, 2004 | 07:09 PM
vtekstorm's Avatar
Default Re: (si_blues)
i got one on my sohc t i gave my friend a ride in my car so he can hear the bov. and he was deciding to get one for his built ls/vtec and he was loving the sound . so now hes getting one for his
dually
Mar 9, 2011 07:47 PM
1DayIllBFast
Jul 10, 2009 06:22 AM
integra3586
Jan 20, 2007 05:49 AM
b18bturbo
Apr 26, 2004 06:46 AM
gpomp
Feb 16, 2004 11:47 PM
