HKS 40mm WG wonders
HKS 40mm WG wonders
OK...I have a revhard equal length with a 40mm HKS flange on it...I really don't want to have it rewelded...can I use this wastegate with a white spring and a boost controller to run around 8 psi?
Re: HKS 40mm WG wonders (Anthonyl469)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Anthonyl469 »</TD></TR><TR><TD CLASS="quote">so this will work good?</TD></TR></TABLE>
i dont see why it wouldnt..as long as you have the right spring..since the white is around 6psi you should be fine..do you already have the spring? if you gonna buy it you might as well just get the orange (7.5psi) and not run a boost controller at all
PINKS
01-22-2007 01:12 PM
92 CIVIC HATCH VX
02-17-2006 02:57 PM
