too much ignition timing bad?
Old Aug 3, 2004 | 08:15 PM
See Are X's Avatar
Default too much ignition timing bad?
Right now i'm running a RevHard 2C turbo kit on my EG with a B16A2 on 6psi. I want to run 8psi...the only thing im concerned about is, im running a chipped P28, that has an NA program that I bought from IH8RICERZ on honda-tech. At 6psi, the car runs great. Would I have any problems turning up the boost to 8-10psi? Would too much advanced ignition cause detonation?
Old Aug 3, 2004 | 08:40 PM
nota944mechanic's Avatar
yes there is a chance of detonation if the ignition timing is too advanced. you need to find out the specs on the chip or run a stock ecu.
Old Aug 4, 2004 | 08:35 AM
See Are X's Avatar
Default Re: too much ignition timing bad? (See Are X)
If I tried it at 8psi witht hat chip, and I don't hear any detonation, does that mean I'm good to go?? Or could I be hurting the motor without me even knowing?
Old Aug 4, 2004 | 09:17 AM
toolowsol's Avatar
regardless of whether your hurting your motor, you are definatly hurting your performance, I would go ahead, download uberdata, and make a chip that reduces your ignition timing as you see boost, also a great opportunity to ditch the crappy fuel management and get something good.
Old Aug 4, 2004 | 09:21 AM
Muckman's Avatar
Moderator in Chief
You dont always hear detonation. Knock sensors rule.
I CRX I
Engine Management and Tuning
15
Mar 27, 2009 06:44 PM
TraKtioN
Oct 5, 2005 04:30 AM
Bigjussin
Oct 21, 2004 04:31 PM
swlabhot
Mar 10, 2003 02:27 PM
rjardy
Mar 3, 2002 06:18 AM
