FI question about cams.
Old Aug 4, 2004 | 02:05 PM
HYREV2NR's Avatar
Default FI question about cams.
Has anyone experimented with using the Type R ex. cam or just install a GSR cam on a B18C5 when using either turbo or a sc? I hear the R intake cam has too much duration & causes too much valve overlap on an FI set up.
Old Aug 4, 2004 | 02:08 PM
RyanEJ8's Avatar
Default Re: FI question about cams. (HYREV2NR)
All you need to do is get some adjustable cam gears and tune your overlap to where you need it.
Old Aug 4, 2004 | 06:04 PM
HYREV2NR's Avatar
Default Re: FI question about cams. (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">All you need to do is get some adjustable cam gears and tune your overlap to where you need it.</TD></TR></TABLE> I was also told that this doesn't work well cause the lobes are so aggressive but this was my ideah to begin with. Thanks for the info anyway. I'll probably be giving that a try.
hybrid2007
Apr 11, 2008 03:12 PM
DC2SIR-G
Mar 10, 2006 09:52 AM
djnikko
Feb 24, 2006 09:09 AM
blkwidow420
Apr 14, 2005 01:37 AM
Dveloped
23
Nov 25, 2003 07:55 AM
