running hot
Old Aug 4, 2004 | 09:02 AM
g2crx's Avatar
Default running hot
hey guy whats up.i just got a quick question.well my cars running a little hotter than normal.and i checked the coolant and i saw a little bit of oil in the coolant.so i was wondering if the headgasket went on it or if it was a sleeve and no theres no coolant in the oil. My set up is ls/vtec je/eagle rods/ rage block gaurd/ arp head studs/ gsr cams/ rev springs /valves/retainers/skunk2 intake manifold/drag manifold/t3t4e turbo/fmic/tial wastegate/255walbro/aem rail ®. and im running the afc hack and i have a p72. so if you guys can give me a opinon on what is wrong i really appreciate it.I mean the cars still pulls really good the only time it gets hot is when im in it for a little bit under normal driving it stays pretty cool like @195-200 but i have my fan on constant also.oh yea im running a OEM head gasket.THANX J.C
Old Aug 4, 2004 | 09:49 AM
g2crx's Avatar
Default Re: running hot (g2crx)
come on nobody has no idea?
Old Aug 4, 2004 | 09:52 AM
Turbo E's Avatar
headgasket for sure. anytime there is oil in coolant or vice versa, its the HG.
id check the thermostat and bleed the system FIRST, just in case
Old Aug 4, 2004 | 11:23 AM
g2crx's Avatar
Default Re: (Turbo E 604)
yea i bleed it already but it still gets hot im hoping that itis the h/g since there was no coolant in the oil.
Old Aug 4, 2004 | 11:51 AM
Nid Styles's Avatar
Default Re: (g2crx)
Check your compression?
Old Aug 4, 2004 | 12:26 PM
g2crx's Avatar
Default Re: (Nid Styles)
the comp. s straight it was like 190 all the way across
Old Aug 4, 2004 | 01:56 PM
g2crx's Avatar
ttt
Old Aug 5, 2004 | 07:22 AM
g2crx's Avatar
nobody else?
joel95ex
Mar 24, 2013 06:28 AM
EJ8Squad919
Jul 9, 2012 02:26 PM
94cpe
Mar 18, 2010 10:46 PM
Dasfinc
Nov 19, 2007 06:59 AM
dustineck
Oct 25, 2003 04:21 PM
