Denso injectors
Old Aug 3, 2004 | 11:22 AM
Rage Cayman's Avatar
Default Denso injectors
My 440cc top out at 350whp and a friend of mine said that he has a set of 680cc.when he took them to me it had densa written on them with numbers like
(095500-00010) this is not the exact number but it is close when i get home i will have the exact number .Can these work and are these really 680cc?? The guy said that it came out of a modified RX7 mazda. Can anyone give me the DENSO part number for the 680cc????
Old Aug 3, 2004 | 11:29 AM
DaX's Avatar
DaX
Loved
Community Favorite
PM b18bturbo
Old Aug 3, 2004 | 11:30 AM
b18bturbo's Avatar
Default Re: Denso injectors (turbocrx2.0l)
the 1985 GSL-SE rx-7 came with the 680cc are they nippondenso injectors that you have. If so then probably thats where they came from. It is widely used injector in the RX-7 communitiy
Old Aug 4, 2004 | 05:02 AM
Default Re: Denso injectors (b18bturbo)
The injectors are denso and the # that is on the side is :195500-0900.
Old Aug 4, 2004 | 07:27 AM
b18bturbo's Avatar
here are all the RX-7 Replacement parts numebrs on the older injectors
195500-0610 Blue top 800cc/m J-spec 12AT RX7
195500-0830 Green 680cc/m J-spec 13B n/a Cosmo
195500-0900 Yellow 720cc/m US-spec 13B RX7 GSLSE '84/85
195500-1350 Red 460cc/m All 13B RX7 n/a '86 on
195500-1370 Purple 550cc/m All 13BT RX7 '85-88
195500-2020 Dark red 550cc/m All 13BT RX7 '89-91, 20BT
Old Aug 4, 2004 | 08:56 AM
Thank alot B18BTurbo. can they work in the AEM fuel rail????
Old Aug 4, 2004 | 10:00 AM
b18bturbo's Avatar
you will either have to cut the top portion of the collar on the injector and use factory orings and you should be okay .
eclipsemf
Nov 8, 2016 01:17 PM
ej8
Feb 26, 2008 08:58 AM
rnbguy
Acura TSX
Jan 21, 2008 01:16 PM
specie
Oct 9, 2002 02:39 PM
