Edelbrock VictorX or Skunk 2?
just wonderin which intake manifold has produced more power in turbo applications..... anyone has tested both on turbo application? I am running 8psi on stock gsr internals for now...... just wonderin which will add more power or are they about the same?
Re: Edelbrock VictorX or Skunk 2? (CrazyHB)
You would probably be happier with the skunk2 manifold on the 8psi you are running now. If you build the motor to run more boost later on the Edelbrock will be better.
Re: Edelbrock VictorX or Skunk 2? (Hella_JDM)
You can run your stock throttle body with it - bolts right up. Edelbrock also has two sizes up from the stocks sizes that fit perfectly also. And then they have two more above those a 70 and a 75mm which require adapters that you can get directly from them also.
SilverLudeSi
12-10-2001 08:44 AM
