What do these gauges do?
Old Aug 5, 2004 | 10:29 AM
frostcivic's Avatar
Default What do these gauges do?
gauges;
Boost; used to view rising/lowering boost pressure in manifold
Stoich air/fuel ; used to view how lean or rich in fuel mixture or balanced(stoich) the engine is running.
Oil Pressure; **not sure about this one**
EGT (exhaust gas temperature) ; used to monitor temperature in exhaust manifold, mainly used for tuning.
are there any other gauges i have not included? what are the 2 most important gauges ? cause i can't be having all these gauges lying around in my eg. i am willing to have a maximum of 3 gauges.
Old Aug 5, 2004 | 10:41 AM
BoostedJeff's Avatar
Default Re: What do these gauges do? (frostcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frostcivic &raquo;</TD></TR><TR><TD CLASS="quote">
Um, normally used to tell oil pressure
Old Aug 5, 2004 | 10:42 AM
Tchleung's Avatar
Throw away the A?F sicne it's jsut a cheap narrowband it won't do you anything. the three most omporntat IMO are BOost, EGT, and oil pressure
In my car I have on the A pillar: Boost, Wideband A/F, oil pressure. In the center console, I have EGT and Oil temp and volt guage(needed to fill last hole) udner that is my boost controller and turbo timer
Old Aug 5, 2004 | 10:43 AM
Tchleung's Avatar
Default Re: What do these gauges do? (JDMHatch4Me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch4Me &raquo;</TD></TR><TR><TD CLASS="quote">
Um, normally used to tell oil pressure</TD></TR></TABLE>
Whoulda woulda thought
Old Aug 5, 2004 | 11:10 AM
frostcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch4Me &raquo;</TD></TR><TR><TD CLASS="quote">Um, normally used to tell oil pressure</TD></TR></TABLE>
oil pressure from to what?
you mean oil pressure to the turbo?
Old Aug 5, 2004 | 11:17 AM
seen4ever's Avatar
engine oil pressure to ensure the lifeline of your engine is still flowing correctly.
i have boost, EGT and oil pressure in my A-pillar
J&S ultra safegaurd monitor, oil temp and water temp in my center console below my AVC-R.
my wideband o2 sits below everything where the ashtray used to be. during the night time i think i'm in an airplane.
Old Aug 5, 2004 | 12:23 PM
Tchleung's Avatar
Default Re: What do these gauges do? (seen4ever)
hah me too. at night time it's a spaceship especially with the indiglo guages and my VAFC that I jsut sue for monitoring now sicne I have hondata(too lazy to sell VAFC) The VAFC is just udner the boost controller and turbo timer. everything lights up blue.
Old Aug 5, 2004 | 01:17 PM
brickonwheels's Avatar
Holy **** that is a lot of gagues.
Old Aug 5, 2004 | 01:33 PM
Rod.'s Avatar
Default Re: (brickonwheels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brickonwheels &raquo;</TD></TR><TR><TD CLASS="quote">Holy **** that is a lot of gagues.</TD></TR></TABLE>
i concur
Old Aug 5, 2004 | 01:35 PM
ms1motorsports's Avatar
Water temp is also an important guage. The stock water temp gauge just not accurate enough for me. A very important gauge for tuning is a wideband meter. This lets you know exactly what A/F ratio you are running almost instantly. AEM wideband sensors are no a gauge type which displays numerical and graphical A/F values. PM me if your interested in the AEM wideband. I am an AEM dealer and can get you a great price. Thanks
Old Aug 5, 2004 | 01:40 PM
T-RO's Avatar
Boost and Oil Pressure and youre good to go
Boost Addict's Avatar
Default Re: What do these gauges do? (ms1motorsports)
I say the more gauges the better. If you have room, why not get as many gauges as you can? When it comes to monitoring your engine, it is important to have as much info as you can.
Old Aug 5, 2004 | 01:41 PM
boosted_dc2's Avatar
i have oil pressure, boost, and egt in my pillar. then i have water temp, and fuel pressure in my guage bezel. i have a wideband display above my steering column, and then a tach on my dash.
if i had to pick 3 they would be, boost, oil pressure, and probably a wideband air/fuel. if you cant afford a wideband then go with the egt.
Landon
Old Aug 5, 2004 | 02:05 PM
Tchleung's Avatar
haha yeah quite a bit of guages. hard tot ake in soemtimes lol.. I also have a shift light too but I did not want that eye sore big thing sticking out anywhere on the dashetc so I put it behind the driver side far vent which usually does nothing anyways You can just see it behind the vent on the very bottom left(blue lens) I left the condom off, so if it is ever too bright. all I have to do is angle the vent fins slightly away from my eye and it's still super bright just not directly at me. it's perfect.
Old Aug 5, 2004 | 02:14 PM
beepy's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I also have a shift light too but I did not want that eye sore big thing sticking out anywhere on the dashetc</TD></TR></TABLE>
I used an RPM switch and some 4500 mCD LEDs, and mounted the LEDs inside the gauge bezel. They're almost invisible, and waaay too bright at night.
Old Aug 5, 2004 | 02:31 PM
Tchleung's Avatar
Default Re: (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">
I used an RPM switch and some 4500 mCD LEDs, and mounted the LEDs inside the gauge bezel. They're almost invisible, and waaay too bright at night. </TD></TR></TABLE>
Hrm sounds interesting. should get some pics of it lit up :D I have a bucnha hypbright LED's I could rig up something but meh I'm too lazy.
Eppo
Jun 25, 2011 06:38 PM
totsie7944
Jun 25, 2007 05:22 PM
Alberto
Jan 30, 2004 05:51 AM
skhonda
May 8, 2003 09:16 PM
slewis
Nov 4, 2001 02:32 PM
