Anyone have; stock ls gt28rs(disco)? want to know if i will like.
Just wondering if anyone has the setup that I am building. It will be a stock jdm b18b with mini-me and gt28rs. Not sure what injectors i will run yet, but we are going to use hondata, 3" exhaust, and less then 10psi. If you have a similar set up please give me feed back on your thoughts. thanx guys.
Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (LoveFabMotorsports)
A redlined B18B welcomes 21 lbs/min of air, and at ~10 psi, thats almost smack-dab in the middle of the 77% 'bubble' on the gt28rs's corrected airflow chart. It equals a max efficiency of 79% for the gt28rs and 77% for the gt28r (guessing since it falls right in the middle on the lines for both).
In layman terms, a great turbo if you ever plan to boost a bit more w/higher redline. I'm in the same boat, but since the LS has the lower torque already, I'm going with the RS. If nothing else, buy a cheap T25 for testing - same boltup as the gt28rs, compressor outlet is slightly different. If you like quick spool & the midrange it gives you, get the gt28r (and sell the t25 for what you bought it for). If its a street/strip car, get the RS.
Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (HiProfile)
Well my goals are pretty low, just want a clean looking fast street car. Looking for about 200 whp, and keep it drivable. I have heard really good things about the gt28rs, just wanted to make sure it is a good match up for my goals. (quick spool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoveFabMotorsports »</TD></TR><TR><TD CLASS="quote"> Looking for about 200 whp, and keep it drivable. </TD></TR></TABLE>
Ha! I think you could make 200 WHp at about 6 psi with that turbo.
I have the larger 3071 w/ .48 A/R, it spools in an instant above 3500. The GT28 will spool even faster.
No worries there!
No worries there!
New User
Don't know if you have seen this before yet. Although its not a LS but its still a gt28rs on an Honda/Acura. http://www.atpturbo.com/root/t...r.htm
Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (integrx)
oh man I didn't realize they dyno tested the gt28RS on a b17. damn taht's EXACYTLY what I wanted tos ee lol. What' the standard inelt size of the GT28RS? 2.75"?
Re: Anyone have; stock ls gt28rs(disco)? want to know if i will like. (Tchleung)
Sounds like the gt28rs is the snail for me. Would be nice to find someone with a b18b/a with the disco on it to ring in.
moncrease
03-07-2008 03:32 AM
