D series turbo questions
Location: With my POS D15B2, Whereever whenever, United States
Forgive me if I sound naive, please someone help me out.
I want to turbo my sohc vtec, what parts should I purchase, so that I can have a reliable 8 psi turbo daily. I want to rebuild my block and run a block guard, I know I need new rods, and I also want to buy new pistons and rings.
Can I get some help, so I can start sourcing out the parts in time for the summer
thanks all
thanks all
Re: D series turbo questions (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">you don't need to build anything in your block to just run 8psi</TD></TR></TABLE>
right, just good management.
Re: D series turbo questions (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
right, just good management.</TD></TR></TABLE>
You can run 8lbs on an FMU/pump just fine.
Re: D series turbo questions (TurboHatch93si)
depends, 8lbs on what turbo?
my sohc was making 244 whp on 10lbs with a t3/t4 , that is a bit much for stock internals.
with a good piston/rod/bearing combo and good tuning your sohc can handle 3-400 whp just fine
now if you just have a small turbo 8psi you can use a fmu and colder plugs and be ok. or even a V-afc and a good fuel pump
good luck!!
good luck!!
Re: D series turbo questions (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost »</TD></TR><TR><TD CLASS="quote">
You can run 8lbs on an FMU/pump just fine.</TD></TR></TABLE>
That isn't true in all cases... my car was leaning out nicely with an FMU and pump... It all depends what size turbo you have on there.
Why not just put uber on it..
well my motor has 130k and i don't know if it has been beaten or not.
I want to do a mild rebuild
What rods pistons and rings do you guys reccomend?
Any shop in the tri state and can partake in this
thanks
NY area i mean
BTW, i need more specific answers.
i appreciate all your help, I'll post up pics in may once I get all my parts settled
being in college sets stuff back.
thanks
NY area i mean
I need help with my mini me setup i have pieced to gether a turbo setup and i would like to get some info on shaving the block on my d 15 b block
Re: D series turbo questions (jdm 94 eg freek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm 94 eg freek »</TD></TR><TR><TD CLASS="quote">I need help with my mini me setup i have pieced to gether a turbo setup and i would like to get some info on shaving the block on my d 15 b block
Um.. how is this relavent to anything..??
The search button is in the top right hand corner. Search mini me swap.
Re: D series turbo questions (Timmay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">depends, 8lbs on what turbo?
good luck!!</TD></TR></TABLE>
damn that is some serious power at 10psi . When did you fully spool?
1st gear i couldnt get over 7 lbs, but right when i hit second full boost.
from a roll in 2nd id have full boost before 5k, maybe 4500-4700?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">That isn't true in all cases... my car was leaning out nicely with an FMU and pump... It all depends what size turbo you have on there.
Why not just put uber on it..</TD></TR></TABLE>
So put a different ratio disk in there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">1st gear i couldnt get over 7 lbs, but right when i hit second full boost.
from a roll in 2nd id have full boost before 5k, maybe 4500-4700?</TD></TR></TABLE>
haha sweet man
haha sweet man
yz125rider21
01-19-2006 08:40 PM
