Oil feed line length GSR
On my b18c, how long should my braided oil line from the back of the block (pressure sensor) to the turbo be?
any suggestions on where to buy it from?
TSPeed Factory
Re: Oil feed line length GSR (b18-c-rx)
it really depends how you wanna route your oil feed line. but 5 feet should be more then enough. you can find them on http://www.summitracing.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx »</TD></TR><TR><TD CLASS="quote">On my b18c, how long should my braided oil line from the back of the block (pressure sensor) to the turbo be?
any suggestions on where to buy it from?</TD></TR></TABLE>
I sell them or http://www.fast-turbo.com Stan is my supplier, quality kits and Stan knows his fittings and line sizes and all that info!!!! Also best pricing around from me and Stan on these since we sell large volumes of these!!!
Re: Oil feed line length GSR (AzntaggeR)
is it legitimate to route my oil line just around the block and into the turbo? will that be enough angle to get the oil into the turbo?
if i wanted to do that, would 5 be reasonable? I dont want random oil lines hanging out like flab.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx »</TD></TR><TR><TD CLASS="quote">is it legitimate to route my oil line just around the block and into the turbo? will that be enough angle to get the oil into the turbo?
if i wanted to do that, would 5 be reasonable? I dont want random oil lines hanging out like flab.</TD></TR></TABLE>
I like to use a Golden Eagle oil filter sandwich adapter with one of Fast-turbo.com's oil feed lines! Great set up, I like to route it towards the passenger side
fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx »</TD></TR><TR><TD CLASS="quote">fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.
PM sent sir.
PM sent sir.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-c-rx »</TD></TR><TR><TD CLASS="quote">fast-turbo.com is down, or something. The buy stuff doesnt work. I want to buy asap, now preferably. I just spent the last like 1 hr figuring out all the fittings so i have that down. all i need now is the length for my oil line - if you can sell a good one to me now, that'd be cool.</TD></TR></TABLE>
Check out his thread here on H-T:
https://honda-tech.com/zerothread?id=1011921
You can just paypal him the required amount to his paypal addy stan@fast-turbo.com
I got my drain line from him, and for $2 he even gave me a cap that I can screw onto my oil pan fitting so that I can still use the same oilpan when I remove the drain line.
Re: Oil feed line length GSR (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">
I got my drain line from him, and for $2 he even gave me a cap that I can screw onto my oil pan fitting so that I can still use the same oilpan when I remove the drain line.</TD></TR></TABLE>
Just FYI I am a Fast-Turbo dealer and work very closely with Stan on his own products and may others! Oil feed/return sold to customer above. Early bird catches the worm.
