need help with my budget build up
i got an ls block, block guard, je 9:1 81.5 mm pistons, eagle rods, z 10 girdle,itr oil pump, cometic gasket, gsr head, itr dual springs , jun retainers,jg 65 mm throttle body, full race turbo kit, t3t4 60-1 garret turbo,dsm 300gt vr4 injectors, dfi gen 6 fuel management, xs engeneering fuel pump, stock tank with sump .. thinking i can run bout 14 psi on this set upand make 350 to 400 hp.. ofcorse last time it was togeather i thought i could run 12 psi on it with no block guard and cracked a sleeve.does any one have a factory sleeved block holding over 12 ps1? also i still need a intake manifold and a fuel pressure regulatorif any body has some used stuff laying around... thanx
