Stupid Apexi Auto timer wiring question
Old Feb 22, 2005 | 09:35 PM
Ls1 FD3s's Avatar
Default Stupid Apexi Auto timer wiring question
i searched, and went on apexi-Usa.com to try and specify this for me.
Car: 94 civic Cx
I dont have the vehicle specific wiring harness which in the Green, Blue, and Red
wires that hookup to the ignition. What they say in the instructions is this:
Red: 12V+ constant --- i can find that wire, no biggie
Blue: IG2 output ---- i can find that wire, but am unsure where to wire in at
Green: IG1 Output ---- i can find that wire, but am unsure where to wire in at
The blue and green are self explanitory, BUT where do they go exactly? I know on the civic's ignition wires (the white ones opposite side of the key tumbler) One always has 12v constant and the other 2 switch on when you put in the key and turn it. Can the Blue and Green wires connect into the same wire? or is there a specific wire that each has to go to? With all my instructions and searching, i have not found anything that tells me this. thanks
-james
Old Feb 22, 2005 | 10:22 PM
Black Si's Avatar
hey man i have the same tt as you and the same car. the red wire goes to the white wire at the ignition switch, the blue wire goes to the black/yellow, and the green goes to the yellow wire. the wires from the tt keep the car running after the key is removed. you need to power the black/yellow and yellow to keep the ignition on and the acc wire will keep the fan running so your car wont overheat. if you need any other help let me know
Old Feb 23, 2005 | 06:11 AM
Ls1 FD3s's Avatar
Default Re: (Black Si)
excellent, il head out to the garage and see if i can locate those wires you speak of.
Old Feb 23, 2005 | 06:16 AM
DaX's Avatar
DaX
Loved
Community Favorite
To be honest man, the best way I can describe how I hooked up my timer [HKS] is I got the 12V constant, ground, ebrake, and RPM wires hooked up then I just started holding the green and blue wires on different locations on the key cylinder until I got the timer to do what I wanted.
Old Feb 23, 2005 | 06:35 AM
Ls1 FD3s's Avatar
Default Re: (DaX)
hahaha, thats what i had planned as my "last ditch effort"
lol
6KAOS6
26
Feb 19, 2011 07:22 PM
SleepnCiViC
16
Oct 30, 2004 11:38 PM
I8ayellowcrayon
May 24, 2004 08:21 PM
poppycock2
Mar 16, 2004 04:45 PM
