Missing link with uberdata?
Old Feb 23, 2005 | 10:13 AM
Treblarefils's Avatar
Default Missing link with uberdata?
Do i need to use the map sensor bypass valve missing link if i run uberdata? Seems as though i see people running it both ways. This is for a 7 psi drag setup running uberdata...also any advantage if i disable closed loop in uberdata?
Old Feb 23, 2005 | 10:23 AM
Frozen E's Avatar
H-T White Ops
no missing link for ueberdata. Ueberdata needs the MAP signal to be able to see what your turbo is doing. the missing link would keep UD from seeing boost and you'd lean out like a **** REALLY quick.
Old Feb 23, 2005 | 10:26 AM
Default Re: (IslandSi)
thanks thats what i thought but figured i better check.
Old Feb 23, 2005 | 11:26 AM
93turbo16's Avatar
http://www.ecimulti.org/uberdata
chrisfromsrq
Sep 26, 2009 12:20 AM
D15Bbigred
Feb 21, 2006 07:57 AM
turboturd98
Dec 24, 2003 07:49 PM
Turbohatch
Jul 2, 2001 10:35 PM
