HELP with my LSD
Old Feb 23, 2005 | 03:24 AM
fjt's Avatar
fjt
Default HELP with my LSD
Ok this is for a Sohc.. I need to know which bearings i have to buy for the OBX LSD.. I bought the Honda OEM ones but they dont fit(too small).
What have SOHC guys with the OBX Differential have used?
here are some pics
I need to solve this today or tomorrow cause were installing my clutch ,flywheel and LSD on Saturday and i need to get the wheel bearings on the differential.
thanks
Modified by fjt at 1:27 PM 2/23/2005
Old Feb 23, 2005 | 05:26 AM
fjt's Avatar
fjt
Checked the part number on the LSD and i have the correct one.. Checked the Bearing part # and it should be the correct one..
Help!!
Old Feb 23, 2005 | 06:12 AM
platinum00's Avatar
Default Re: (fjt)
I have the same LSD installed.
this is what you need.
41312-PL3-B00 speedo gear
91005-PS1-003 Diff bearing, need 2
91002-PSO-003 ISB bearing
91216-PL3-005 ISB seal
23927-PL3-000 thrust washer
23928-PL3-000 thrust washer
platinum.
Old Feb 23, 2005 | 06:22 AM
fjt's Avatar
fjt
thank you man!! are these Honda OEM parts?
so this is the bearing i need?--->91005-PS1-003 Diff bearing, need 2
Old Feb 23, 2005 | 06:31 AM
platinum00's Avatar
Default Re: (fjt)
no problem.
yea just go to the dealer ship and give them those numbers.
they should be able to pull it up
i think it's like 125 for everything.
platinum.
Old Feb 23, 2005 | 06:35 AM
MooreBoost's Avatar
Default Re: (platinum00)
Why do you need these new parts?
Old Feb 23, 2005 | 06:38 AM
platinum00's Avatar
Default Re: (MooreBoost)
you can use your old ones if you want.
just not a good idea. When removing them from the old diff they can get messed up and cause serious problems later.
platinum
Old Feb 23, 2005 | 06:54 AM
MooreBoost's Avatar
I guess I thought OBX would include them, I should have known better.
Old Feb 23, 2005 | 06:56 AM
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">you can use your old ones if you want.
platinum</TD></TR></TABLE>
Yeah my mechanic sees it as taking a shower and putting the same dirty underwear..lol je je je
Old Feb 23, 2005 | 06:58 AM
platinum00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">I guess I thought OBX would include them, I should have known better.</TD></TR></TABLE>
haha, yea,
that's one thing people dont relize when buying these. is that quaffe includes the new ****, and OBX does not. that's prolly how hey offset the price a little
platinum.
Old Feb 23, 2005 | 07:01 AM
fjt's Avatar
fjt
I called the honda parts and well it turns out they gave me the CX tranny diff. bearings(since i have a CX EK)..aparently the EX tranny has bigger bearings and share the same part number as the Integra LS differential bearings.
Old Feb 23, 2005 | 07:09 AM
platinum00's Avatar
Default Re: (fjt)
cool..
good luck man.
the diff feels real nice.
Old Feb 23, 2005 | 07:44 AM
rioninja's Avatar
Default Re: HELP with my LSD (fjt)
Hey, can you do me a favor while you have it apart? Can you measure the LSD from end to end for me? I would appreciate it man!
Old Feb 23, 2005 | 08:49 AM
fjt's Avatar
fjt
Ill try to do it tonight
Old Feb 23, 2005 | 11:06 AM
rioninja's Avatar
Default Re: (fjt)
thanks a lot
Old Feb 23, 2005 | 12:02 PM
jason190's Avatar
Default Re: (rioninja)
I just installed the OBX last month.......It didn't even come with any type of instruction at all....Or parts. But either does the Quaife. Other then that I love it. It's a good piece.
Old Feb 23, 2005 | 05:41 PM
unsungsohc's Avatar
Default Re: (jason190)
I put my obx lsd into a z6 tranny and had crazy clearance issuses between the casing and the diff. i had to get the shim milled down because honda did not make a small enough one. Did anyone else have this problem?
Old Feb 24, 2005 | 04:38 AM
platinum00's Avatar
Default Re: (unsungsohc)
the z6 is like that, on the y8 it has the same problem but its not as bad.
i just did not use a shim..
platinum
Old Apr 11, 2005 | 10:22 PM
nikitad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unsungsohc &raquo;</TD></TR><TR><TD CLASS="quote">I put my obx lsd into a z6 tranny and had crazy clearance issuses between the casing and the diff. i had to get the shim milled down because honda did not make a small enough one. Did anyone else have this problem? </TD></TR></TABLE>
Having it as we speak with an 89 tranny.
Old Apr 11, 2005 | 10:32 PM
AspectIndustries's Avatar
Default Re: (nikitad)
Err..
Old Apr 11, 2005 | 10:33 PM
Good to see lots are having great sucess with these LSDs Anyone ever done a writeup on installing one of these themselves? Be awsome (i may be blind)
Old Apr 11, 2005 | 11:40 PM
714phil's Avatar
haha, yea,
platinum.</TD></TR></TABLE>
what does quaife include? what is the "new ****"?
Old Apr 12, 2005 | 05:09 AM
JustinL's Avatar
Default Re: (STD ONEpointSIX)
i have a phantom grip, would it be worth it to install or should i sell it for the obx lsd?
Old Apr 12, 2005 | 05:18 AM
corso28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">haha, yea,
i wish my quaife came with new bearings. woulda saved me 120 bux.
Noah Santana
Sep 1, 2016 06:01 PM
SilverEK96
Transmission & Drivetrain
Jul 21, 2015 05:30 AM
SilverEK96
May 13, 2014 08:00 AM
Nameless RB26
Dec 14, 2002 11:06 AM
