stock fuel rail???
stock fuel rail???
so i am only going to be running .5 bar for now... 255walbro HP + RC Sat. 750cc
p28 (crome program)
on my 99 gsr...
will the stock fuel rail work? or do i need a new one?
p28 (crome program)
on my 99 gsr...
Re: stock fuel rail??? (wantboost)
fitting the rc's in there wouldn't be a problem? how many hp until i need to upgrade my fuel rail? also... would you recommend me getting a FPR for better tuning or not needed for sub 300whp applications?
Re: stock fuel rail??? (SHystrdyGSRtdy)
The stock fuel rail will be sufficent. But the fuel pressure and ignition should be set to stock before tuning. You may want to pick up a fuel pressure gauge to make sure that your fuel pressure is at stock (42psi) and ignition at (16degrees).
