cant boost over 4 psi
i just got my car back together last week and i now i have a problem with my boost. it wont boost over 4 psi and i was wonering if anybody had an idea. i think it might be a small leak somewhere. i double checked all the vacum hoses and all the lines coming to and from the turbo and there all fine. i was just wondering if anybody had an idea on what it could be.
Re: cant boost over 4 psi (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">could be a exhaust leak b4 the turbo , or boost leak in the charge pipes </TD></TR></TABLE>
Re: cant boost over 4 psi (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro »</TD></TR><TR><TD CLASS="quote">fixed it it was a boost leak in the charge pipe</TD></TR></TABLE>
Where or which charge pipe was it? cuz im only hitting 5psi and i have a 10psi spring! so i have same problem, it might be loose in the same area
Re: cant boost over 4 psi (USDMx05)
its actually a tear in the connecting piece from the trubo to the charge pipe so i have to replace it. it still does it sometimes it will boost and sometimes it doesn't. but i also think that it might be my waste gate because i dont hear it open at all.
Re: (USDMx05)
now that i got my charge pipe fixed now i have anothe problem. i have a 9 psi spring but i will go past that and i dont have a boost controller can anybody tell me why this is happening
Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro »</TD></TR><TR><TD CLASS="quote">now that i got my charge pipe fixed now i have anothe problem. i have a 9 psi spring but i will go past that and i dont have a boost controller can anybody tell me why this is happening</TD></TR></TABLE>
So, you are over boosting? How much? Is it just spiking or holding steady at a higher boost level?
I would be careful if I were you... overboosting can be the end of your motor
Location: hittin corners so hard you can taste my rims..
Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro »</TD></TR><TR><TD CLASS="quote">im not for sure what it goes to but it was at 11psi and i backed off the gas. so i dont know if it stops there or keeps going.</TD></TR></TABLE>
on a FMU...
on a FMU...
Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro »</TD></TR><TR><TD CLASS="quote">i will check my wastegate tonite after work its an external wastegate and im runnuing a vafc. is it possible that the spring broke.</TD></TR></TABLE>
I don't see how the spring could break but I would inspect the wastegate to make sure it's working properly...
