Help Leaking sleeves
Old Feb 22, 2005 | 10:05 AM
crxhf19's Avatar
Default Help Leaking sleeves
ok heres the deal, ive got an ls with sleeves but in by my local machine shop. i put my swap in and i keep on losing antifreeze. i call a performance shop and they tell me that more than likely the sleeves are leaking. i jack my car up and take off the oil pan, windage tray, and oil pickup. i compress my system with air and slowly but surely water droplets form on the bottom of my sleeves.
have any of you guys ever heard of this and what can i do to fix this? is there some kind of miracle stop leak on the market? what have you guys done? this really sucks because i paid the shop 1300 dollars ans some odd change and this is what i got. they wont warrenty it. wtf im stuck and heart broken HELP!!!!!!
Old Feb 22, 2005 | 11:22 AM
ProjectDarkBlack's Avatar
Default Re: Help Leaking sleeves (crxhf19)
well it sounds like you have a hairline crack in one of your cyclinder walls, that or the shop that did the work didnt press them in right and they arent sealing against the block
Old Feb 22, 2005 | 11:31 AM
adictionbass's Avatar
Default Re: Help Leaking sleeves (ProjectDarkBlack)
It shouldnt have anything to do with a warrenty. It has to do with them doing the work you paid them to do, 'correctly'. It sounds like they didnt.
Old Feb 22, 2005 | 11:35 AM
B18C1CYA's Avatar
if it was me i would pull the motor and take it back , they messed it up and should fix it free of charge
Old Feb 22, 2005 | 11:55 AM
stealthmode62's Avatar
Default Re: Help Leaking sleeves (B18C1CYA)
Damn, it sounds totally like the shop is at fault. I also have been talking to a couple shops about sleeving in my local area, but if they want to charge the same price as guys that do it everyday (list big sleeving companies here) than you're just better off sending it out.
I think the completely correct way to fix the problem would be to talk to one of the larger sleeving companies and see if anyone want's to attempt to fix the problem. If you can get one of them to do it, at least your block will be in good hands. Good luck.
Old Feb 22, 2005 | 12:30 PM
G
sh!t happens.
Default Re: Help Leaking sleeves (stealthmode62)
Damn man that suxs.. They should warrenty there work.. Take the **** to them and show them whats going on. I know when I do sleeves again i am going with Beason or Golden Eagle.
Old Feb 22, 2005 | 03:16 PM
PrettyLude's Avatar
i sent my block to bensons=their customer service is great
BoostGoneWild
Dec 30, 2014 09:10 AM
oneson1985jim
Feb 21, 2010 03:36 PM
iiilgsrlll
Dec 26, 2004 12:56 PM
