turbo d16 [z6 or y8]
ive been hearing diff amts of oil to put in. stock i believe is 3.5qt. some ppl say put 4, i usually do ~3.75gt. what are ya'll puttin in ?
f.y.i. mobil 1 syn 10w30
Re: turbo d16 [z6 or y8] (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">stock is 3.5 i usually add 1/4 quart for the turbo.</TD></TR></TABLE>
Same.
Same.
Re: turbo mini me
Anyone help me i have a large problem i have project car i would like to finish by 2/27/05 and i need some help first i need a front mount reasonaly cheap and a info on shave a block down for turbo clearance
Re: turbo mini me (jdm 94 eg freek)
you mean notch the block? all you do is take a grinder and shave off part of the webbing on the motor. just enough so the turbo wont rub. get a johnny racecar fmic. like 180 shipped . i customized a starion fmic to get 2.25 endtanks
i don't think oil lines and the turbo holds 1/2 quart, its probably around 1/4 of a quart, maybe a bit less, but i would just do 3 3/4 and not 4 quarts
Re: turbo d16 [z6 or y8] (W O T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Ya I would think your oil feed/return/turbo itself and if you have a mechanical would be just about (little under) a quarter quart</TD></TR></TABLE>
what mechanical thing are you talking about ?
I put regular Mobil 1 - 10w40 for $1.18 /bottle .... car holds 3.5 Qt, dont put more than 3.75 ...as for how much the turbo holds - put 3.5 Qt and see where the mark on your dip stick is so add a little more ... on mine stock D16Z6 with 3.5 qt it goes up to the upper mark
if you put 4 qt then your oil will rise its temperature - not much, but you don't want it hotter but rather cooler
Re: turbo d16 [z6 or y8] (miro_gt)
Your oil temp will decrease with more oil obviously, more surface area, more mass for the molecules to lose speed hence cooling down
I put 4qt in mine because I aint boosted and she eat a quart every 550-600km/s
obviously it won't!
-> more oil -> need more time to cool off ->keep higher temperature
Also, the speed of the molecules does not depend on mass, it depends on density, temperature, mixtures... Learn some physics
did an oil change today to see. i did 3.75 and it worked out fine. did 3.5 first, started car for 10-15sec. turned off, checked dip stick, added another 1/4. and it was all good.
