Stock map sensor more capable at high altitude???
Old Feb 24, 2005 | 08:02 PM
Raf's Avatar
Raf
Default Stock map sensor more capable at high altitude???
I've searched already and I found nothing on the subject.
As far as I know, a stock D16 map sensor reads about 10 PSI (give or take .5). If I'm correct, this is a total of 24.7 including atmospheric pressure at sea level. if I go to a higher altitude where atmospheric pressure is 11.7, will the stock map sensor be capable of reading 13 PSi for a total of 24.7?
In simpler terms...does the stock map sensor max out at 10 PSI regardless of elevation or does it max out when it reads a TOTAL of 24.7 PSI?
Old Feb 24, 2005 | 08:37 PM
beepy's Avatar
Default Re: Stock map sensor more capable at high altitude??? (Raf)
Total. The MAP sensor's voltage reports absolute pressures.
Old Feb 24, 2005 | 11:38 PM
adseguy's Avatar
Default Re: Stock map sensor more capable at high altitude??? (beepy)
If you want to tune for higher boost levels the stock map won't read above 11 PSI, but you can tune for as much as you want. the map will just read the 11 PSI column and stay there even if your actual boost is a lot higher. Get it?
Old Feb 25, 2005 | 07:54 AM
Raf's Avatar
Raf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Total. The MAP sensor's voltage reports absolute pressures.</TD></TR></TABLE>
So it'll read lower voltage when you're at higher alitude? I just wanna confirm this.
krugozor
Feb 21, 2011 08:38 PM
Ldo
Oct 9, 2010 03:35 PM
hatchBK4life
Feb 3, 2010 12:08 PM
Honda4life777
Jul 6, 2009 09:00 PM
Mr. Softee
Mar 25, 2003 07:29 PM
