I need advice of what turbo I need for my setup?
First off I have searched, but I cant read compressor maps. I need to match what turbo I need for my set up. Right now I have turbonetics t3/tO4e 57 trim 63a/r stage III. This turbo is really laggy on my car, I was thinking of switching to a 48a/r to get a faster spool on a more usable rpm range or switch turbos. What is your opinion should I switch exhaust housing or turbo and what turbo do you guys recommend? Thanks for all you help and opinios> PS Im reving to 8k HP goal is 350 but more power is alwasy welcome.
Set up:
d16z6
BOTTOM:
wiseco.20overbore /scat rods 8.8.1 compression
GE blockguard
arp bolts everywhere/fully balance and blueprinted
HEAD:
zex/comp
cam/sprocket
stock valves and comp spring retainers
edelbrock Intake manifold
FUEL:
fuel RC 550
AEM fpr
BBK 255 fuel pump
hondata S100b
AVCR
all kind of guages oil/boost/tach/egt
TURBO:
boost cooler methanol injection kit
Tial w/g
revhard manifold
greddy type s
street import hughe intercooler
2.5 dp flared to 3"
Modified by booscivic at 4:27 PM 2/27/2005
Set up:
d16z6
BOTTOM:
GE blockguard
HEAD:
zex/comp
cam/sprocket
FUEL:
fuel RC 550
AEM fpr
BBK 255 fuel pump
hondata S100b
AVCR
TURBO:
Tial w/g
revhard manifold
greddy type s
2.5 dp flared to 3"
Re: I need advice of what turbo I need for my setup? (booscivic)
I was told my .48 would fall off on the top end while shooting for 350, and to switch to a .63.
How about running a 55 shot on it to spool the turbo? I might do that.
I dont really want to do nitrous, I was told this turbo can support 500,if thats true then 350 is should be no porblen and the compressor 60a/r is big for higher rpm range
check out http://www.phoenixturbo.com talk to ken he can switch you out to a .48 ar which will spool much faster and give a much more usable powerband ...especially for you d-series
The least expensive thing would to just switch out the turbine housing. Much less expensive than going ball bearing.
I've got a.48 A/R on my 2.3L (that's the factory set up) and it comes on like a light switch, but I'm not making the power you are.
Just be sure it's machined specifically for that wheel.
Rod Short
Sales Manager
Precision Turbo
Rod Short
Sales Manager
Precision Turbo
Accidently deleted my last reply
If you are not ready to purchase a turbocharger I would follow Rod Short's advice. If you are talk to a Garrett/Precision dealer, Arturbo/ForcedAir/Flamenco-T/TheShodan/Full-Race Motorsports/SPARK RACING INC./This One/Tinker219 and others, and they will be able to properly size a turbocharger for you.
We (Trip, Blown90Hatch and I) are going to be testing a GT3255E on a Wiseco/Eagle D16 here soon. I will let you know how it goes when I can
booscivic
03-07-2005 02:35 AM
