Flex pipe on downpipe yes or no?
Old Feb 23, 2005 | 09:14 PM
ppfalcon's Avatar
Default Flex pipe on downpipe yes or no?
I am curious is it worth getting a flex pipe when you make your downpipe?
Old Feb 23, 2005 | 09:15 PM
93turbo16's Avatar
yes, definitley worth it man..
Old Feb 23, 2005 | 09:16 PM
Black DC2's Avatar
Default Re: (93turbo16)
ye sif not the downpipe will break like it did to me twice
Old Feb 23, 2005 | 09:36 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">yes, definitley worth it man..</TD></TR></TABLE>
Old Feb 23, 2005 | 09:38 PM
wantboost's Avatar
Who is Mr Robot?
Old Feb 23, 2005 | 09:47 PM
xboostin4funx's Avatar
Default Re: Flex pipe on downpipe yes or no? (ppfalcon)
they are right the pipe might break for street use it would be smart, but in my personal experience my friends drag ek had problems w/ the flex portion. it kept comming unraveled internaly and resitricting the exhaust even more, but that was under high psi we used an eliminator pipe and worked fine
Old Feb 23, 2005 | 09:59 PM
turtle-eg's Avatar
Default Re: (Black DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black DC2 &raquo;</TD></TR><TR><TD CLASS="quote">ye sif not the downpipe will break like it did to me twice </TD></TR></TABLE>
Either the downpipe breaks or the manifold cracks which is worse.
Old Feb 23, 2005 | 10:35 PM
SHystrdyGSRtdy's Avatar
Default Re: (wantboost)
yes, it will help with those large vibrations but the ones of higher frequency that tends to loosen bolts etc.. a flex pipe won't do much for it.
Old Feb 24, 2005 | 08:06 AM
projectxspeed's Avatar
Default Re: (SHystrdyGSRtdy)
agreed. Flex pipe has a lot of advantages over a solid pipe. I am going to use one on my LS-T
Old Feb 24, 2005 | 08:15 AM
Finland's Avatar
Default Re: (projectxspeed)
I didn't like the idea of a ribbed flex section, so I made my own ball and socket that is true 3" and uses off the shelf parts
Old Feb 24, 2005 | 08:41 AM
PM-Performance's Avatar
Default Re: (turtle-eg)
i never had a problem and didnt use them . Exhaust hangers alow the exhaust to move with the motor. That should be enuff.
Old Feb 24, 2005 | 09:18 AM
Evanmb44's Avatar
Default Re: (itr206)
it wouldnt hurt to have one
Old Feb 24, 2005 | 09:48 AM
Muckman's Avatar
Moderator in Chief
Default Re: (Boondock Saint)
Why dont you like the idea of a flex pipe? It way cleaner than that mess you got going on under your car.
Old Feb 24, 2005 | 09:56 AM
1Bar GSR's Avatar
Default Re: (Muckman)
Yes a flex pipe or when your moto torques you might crack your downpipe!
Old Feb 24, 2005 | 10:46 AM
DriveSlowHomie's Avatar
Default Re: (1Bar GSR)
wow...i didnt know a flex pipe was this important....currently build a turbo setup...where can i find the flex part of it?....i already have a revhard downpipe
Old Feb 24, 2005 | 10:55 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Why dont you like the idea of a flex pipe? It way cleaner than that mess you got going on under your car.</TD></TR></TABLE>
Easier maybe, but not any better. The assembly in the photo is about 6" long total, very compact, I can un bolt the whole thing if I want, the gasket is replaceable, and the inside isn't ribbed like your flexjoint, which I already stated in the previous post.
It is a very well engineered piece that will never break, or rot. If you want to call that a mess, whatever...
Old Feb 24, 2005 | 10:58 AM
b18a2turbo's Avatar
the motor torques front to back on a fwd car it's needed. On a rear wheel drive it's not need because it torques side to side
Old Feb 24, 2005 | 11:32 AM
dennis's Avatar
I bolted my downpipe to the backside of the block, so that ****** is rock solid. I did put a flex pipe on the opposing side of the clamp where it clamps to the exhaust though just for safety's sake.
Old Feb 24, 2005 | 11:47 AM
turbosi03's Avatar
Default Re: Flex pipe on downpipe yes or no? (dennis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint &raquo;</TD></TR><TR><TD CLASS="quote">
It is a very well engineered piece that will never break, or rot. If you want to call that a mess, whatever... </TD></TR></TABLE>
I think that setup is pimp!
thats not a mess at all, maybe a little rust, but a great mechanical design peice in my eyes...
Old Feb 24, 2005 | 12:09 PM
civicb18c's Avatar
would it matter if the flex pipe is on ur exhaust piping instead of it being ON the downpipe?
Old Feb 24, 2005 | 12:23 PM
Evanmb44's Avatar
go to kteller.com for the flex piping
Old Feb 24, 2005 | 12:29 PM
junkyard racer's Avatar
Default Re: (Evanmb44)
as someone else mentioned, i would think the hangers would be enough to flex with
Old Feb 24, 2005 | 12:34 PM
EJ1 wilcox's Avatar
Default Re: (junkyard racer)
I am using an 8" flex pipe on my downpipe... I just wanted to be sure that I wasn't going to crack anything... plus I got a good deal on one, only $10!
I am not using spring bolts to connect the downpipe to the cat so I wanted to make sure that there was a little room for movement...
Whether you use a flex section or spring bolts I would recomend making sure your engine has at least a little room for movement other than the exhaust hangers... it's pretty cheap insurance against cracks if you ask me...
Old Feb 24, 2005 | 12:41 PM
99blusi's Avatar
Default Re: (EJ1 wilcox)
Damn Jan...that's an interesting piece of work there.
Old Feb 24, 2005 | 01:16 PM
Muckman's Avatar
Moderator in Chief
I wouldnt exactly call that engineering. And yes a flex pipe wont exactly be smooth on the inside but neither is yours. Everytime it goes from flange to pipe to flange to ball joint to whatever theres going to be a small interuption in flow too.
