stupid ? but what size t bolts do i need?
i want the connection to be tight... but i don't want to buy a t-bolt that's too small or too large...
for my charge piping being 2.5"... please consider the thickness of the silicon hose coupler too...
so do i get the 2-1/4 - 2-9/16" or the 2-1/2 - 2-13/16" t-bolts? (inner diameter of my silicon couplers = 2.5")
Re: stupid ? but what size t bolts do i need? (SHystrdyGSRtdy)
I ordered some 2 inch couplers from ATP turbo, and the 2.25 inch t bolts i got were too small. I had to send them back. But the 2.5 inch t bolts fit the 2.25 coulpler fine.
Re: stupid ? but what size t bolts do i need? (DurboDug93)
2-1/2 - 2-13/16" t-bolts, if you measure the outer diameter of your coupler should be bigger than 2.5" something like 2.60"-2.70"
Re: stupid ? but what size t bolts do i need? (oxSLEEPERxo)
if you coupler is 2" then get 2.25inch if you coupler is 2.5" get 2.75 if you coupler is 3" get 3.25 simple as that
if i use 2.5 inch i/c piping. which t bolt clamps do i use, and what size silicone couplers do i use
B16Civic93
07-04-2005 05:09 AM
