Timing question
Old Feb 22, 2005 | 04:45 PM
CRXdan's Avatar
Default Timing question
I have a 87 CRX Si thats been converted to OBD0 and I forgot to run the wire to jump the dizzy to set base timing. On my tuboedit ignition map I am at 21 degrees of idle at 500-1000rpm from anywhere at 20in hg to 22in hg
So my question IS
Can I let my motor idle and set the timing to 21 degrees with the timing gun without jumping the dizzy?
Old Feb 22, 2005 | 04:48 PM
beepy's Avatar
Default Re: Timing question (CRXdan)
No. The electronic control is analogous to the "vaccum advance" on old distributors. If you don't disconnect it your timing will be jacked.
Old Feb 23, 2005 | 07:04 AM
CRXdan's Avatar
OK lets try it a diferent way. I have a 90 civic si running turboedit and I want to set the timing. I am too lazy to jump the dizzy and my turboedit ignition map reads 21 deg advance at idle from 500-1000rpm at 22in HG.
Can i just set the timing to 21deg advance with the timing light without jumping the dizzy?
This has NOTHING to do with vac advance distributors. The motor is a 89 d16a1
Old Feb 26, 2005 | 11:16 PM
CRXdan's Avatar
ttt
prodjay10
May 6, 2016 10:43 AM
Boosted Chemist
Aug 20, 2005 07:25 AM
the.hamburglar
Aug 8, 2005 01:12 PM
P1mpSlap
Jul 29, 2003 10:17 PM
93SSPHatch
Jan 19, 2003 11:32 AM
