Best manual boost controller?
Old Feb 24, 2005 | 07:31 PM
s2k drifter's Avatar
Default Best manual boost controller?
Turbosmart or TurboXS....Which is a better buy? I'm looking to get somthing easy to use and basically simple so im going with a manual controller.
Old Feb 24, 2005 | 07:35 PM
T4eg's Avatar
Default Re: Best manual boost controller? (EK project hybrid)
the turbo xs uses allen keys and the turbo smart uses *****. Other than that i figure both are the same. I am using the turbo xs dual stage.
Old Feb 24, 2005 | 07:39 PM
Default Re: Best manual boost controller? (BlueHatch00)
Is it possible to install either controllers inside the car? Im just about done with my turbo kit and need little things like oil lines and a adaptor. Cant wait to boost my ek
Old Feb 24, 2005 | 08:36 PM
Tchleung's Avatar
Hallman pro HX or whatever has incar adjsutability and is still MBC. Hallman makes some of the best
Old Feb 24, 2005 | 08:40 PM
dornon13's Avatar
Default Re: (Tchleung)
couldnt any of them be in the cabin...you just need long vacuum hoses right?
Old Feb 24, 2005 | 08:47 PM
Default Re: (dornon13)
I was thinking that myself. So what is the best manual boost controler? I heard some controllers tend to break... is that possible? Im looking to boost on my stock gsr motor. My next question was going to be should I buy egt gauge or wideband? Being that im going to use stock internals, which would be a better choice? Well I did some research and decided to buy a hondata s200 with boost so hopefully that would help.
Old Feb 24, 2005 | 08:48 PM
Tchleung's Avatar
no you want MBC or any boost controller vacuum lines to be as SHORT as possible for accuracy and response. the hallman one is like a standard MBC udner the hood, but it coesm witha line comnig off it that goes to your cabin taht you montu that you can turn. Kinda like... a throttle cable.sorta kinda.. not. lol
Old Feb 24, 2005 | 08:50 PM
Tchleung's Avatar
EGT about 1-2" from the head on #3 runner.
Wideband in the downpipe about a foot+ from turbo ppl say, Ive had miens 6" from turbo no problem.
Old Feb 24, 2005 | 09:01 PM
I didnt pick up a egt yet, maybe I should look into a wideband. Whats the biiiiiiiig difference though? I mean the egt can tell you the exhaust temp which is usefull so your engine wont blow....but then again the wideband can tell you if your running rich or lean. So, whats a better choice? keep in mind im planning on running boost on stock gsr motor and im keeping ac . So hallman boost controller is the better choice huh. Anyone second this opinion?
Old Feb 24, 2005 | 09:55 PM
*Boostwerks*'s Avatar
Definetly NOT the greddy tvvc look-a-like that project boost sells.
It looks nice, but man is it a POS!
Old Feb 24, 2005 | 10:02 PM
spoolint78's Avatar
most mbc's are not that great.
best i've heard were just ball and spring ones.
Old Feb 24, 2005 | 10:13 PM
Default Re: (spoolint78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolint78 &raquo;</TD></TR><TR><TD CLASS="quote">most mbc's are not that great.
best i've heard were just ball and spring ones.</TD></TR></TABLE>
Not true.
Most professional drag guys run MBC's because they're relaible and work fine. Plus why spend money where it's not needed?
Old Feb 25, 2005 | 12:59 AM
project dc2's Avatar
Default Re: (Bryson)
i run a hallman pro from boostcontrollers.com
Old Feb 25, 2005 | 03:21 AM
Importracer_001's Avatar
I had the the turbo XS standard boost controller it was simple but I had boostspike issues with it.
Now I have the Turbosmart dualstage it works like its supposed to and no longer have spiking issues.
Old Feb 25, 2005 | 05:14 AM
quicksol95's Avatar
Default Re: (Importracer_001)
check out the site in my sig
Old Feb 25, 2005 | 05:28 AM
PM-Performance's Avatar
Default Re: (EK project hybrid)
Hallman is an awesome controller. I ran one before. I got an TurboXS dual stage now becuase i wanted some room to play and switch hi/lo settings.
They both work out great for me.
Old Feb 25, 2005 | 06:17 AM
powerls's Avatar
TurboXS is junk, spikes like crazy. Plus, I hated the fact that you have to use a allen key to adjust it. Turbosmart MBC are great. It just uses a simple **** and it has a detent feature which causes the MBC to click as you turn it. Not only does this help in tuning, but it will also prevent the **** from backing itself out while it is shaking in the enginge bay.
Old Feb 25, 2005 | 06:24 AM
dornon13's Avatar
Default Re: (powerls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">no you want MBC or any boost controller vacuum lines to be as SHORT as possible for accuracy and response. the hallman one is like a standard MBC udner the hood, but it coesm witha line comnig off it that goes to your cabin taht you montu that you can turn. Kinda like... a throttle cable.sorta kinda.. not. lol</TD></TR></TABLE>
ok now what would it affect if you did have lines that long...my friend had his rigged this way in his non-honda seemed to work fine
Old Feb 25, 2005 | 06:39 AM
Evanmb44's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK project hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I didnt pick up a egt yet, maybe I should look into a wideband. Whats the biiiiiiiig difference though? I mean the egt can tell you the exhaust temp which is usefull so your engine wont blow....but then again the wideband can tell you if your running rich or lean. So, whats a better choice? keep in mind im planning on running boost on stock gsr motor and im keeping ac . So hallman boost controller is the better choice huh. Anyone second this opinion?</TD></TR></TABLE>
get the zeitronix wideband w/ lcd display. it has a display for the egt on it so you can just purchase a probe from them with it. i would run both but that is just my opinion
Old Feb 25, 2005 | 06:41 AM
my turboxs works great soo far. If there is spiking you should look into other things and test more before you blame it on the controller.
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">my turboxs works great soo far. If there is spiking you should look into other things and test more before you blame it on the controller.
Beat me to it. I've had no issues from my Turbo XS.
Old Feb 25, 2005 | 07:20 AM
b18-c-rx's Avatar
Default Re: (DaX)
Poor man's MBC:
http://www.geocities.com/chmwatson/FAQs/mbc.html
Old Feb 25, 2005 | 07:25 AM
EJ1 wilcox's Avatar
Default Re: (b18-c-rx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerls &raquo;</TD></TR><TR><TD CLASS="quote">Turbosmart MBC are great. It just uses a simple **** and it has a detent feature which causes the MBC to click as you turn it. Not only does this help in tuning, but it will also prevent the **** from backing itself out while it is shaking in the enginge bay.</TD></TR></TABLE>
This is why I'm getting the turbosmart MBC, I like the design and the clicking mechanism, it's easy to adjust the boost and I haven't heard any complaints about it...
Old Feb 25, 2005 | 07:31 AM
B18Flip's Avatar
Default Re: (EJ1 wilcox)
my dad uses a hallman pro in his evo...holds boost steady @ 21psi
Old Feb 25, 2005 | 08:00 AM
Default Re: (Evanmb44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evanmb44 &raquo;</TD></TR><TR><TD CLASS="quote">
get the zeitronix wideband w/ lcd display. it has a display for the egt on it so you can just purchase a probe from them with it. i would run both but that is just my opinion</TD></TR></TABLE>
Are you using the zeitronix wideband? Lcd display sounds great, if this wideband has both options then I most likely would use both. Anyone using Widebands in here? What brands are good and which just plain old suck?
