greddy td04 kit?
Old Feb 24, 2005 | 08:53 AM
CAE's Avatar
CAE
Default greddy td04 kit?
hey guys i have a td04 greddy kit,i had fully adjusted to 8lb boost,is there anyway i can boost higher?and will i get it to boost higher,and what do i need to do?thnks guys.
Old Feb 24, 2005 | 09:06 AM
beepy's Avatar
Default Re: greddy td04 kit? (CAE)
Manual or electronic boost controller. If the wastegate actuator is set at 8 PSI, you can easily go to 16 with a MBC. Will the engine survive? Maybe if you get it tuned right.
Old Feb 24, 2005 | 12:41 PM
PrettyLude's Avatar
Default Re: greddy td04 kit? (beepy)
Old Feb 24, 2005 | 02:50 PM
VTECTURB0's Avatar
Default Re: greddy td04 kit? (PrettyLude)
correct me if im wrong but doesnt the td04's stop making boost around 11 or 12psi? isnt it just blowing in hot air after that?
Old Feb 24, 2005 | 03:11 PM
honda9369's Avatar
Default Re: greddy td04 kit? (VTECTURB0)
its a td04-19t capable of pushing 300+hp. its an upgrade for the 3000gt. now tell me if it only pushes 11psi
Old Feb 24, 2005 | 03:16 PM
CAE's Avatar
CAE
Default Re: greddy td04 kit? (honda9369)
ok i got it to boost at 12lbs by adding washers,but now everytime i reach boost my motor starts make popping noise,now whats wrong with it?advice please,thanks
Old Feb 24, 2005 | 03:18 PM
CAE's Avatar
CAE
oh and also if i upgrade my fuel pump,do i have to upgrade my injectors too or can i stay with the stock injectors?thanks
Old Feb 24, 2005 | 04:21 PM
miro_gt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAE &raquo;</TD></TR><TR><TD CLASS="quote">ok i got it to boost at 12lbs by adding washers,but now everytime i reach boost my motor starts make popping noise,now whats wrong with it?advice please,thanks</TD></TR></TABLE>
Dont push it anymore ... go tune it .. or soon you'll be driving another car until you fix that one ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAE &raquo;</TD></TR><TR><TD CLASS="quote">oh and also if i upgrade my fuel pump,do i have to upgrade my injectors too or can i stay with the stock injectors?thanks</TD></TR></TABLE>
You drive 12psi with stock fuel pump and injectors ... oh man .... Anyway, get fuel pump and injectors at the same time
Old Feb 24, 2005 | 04:35 PM
93turbo16's Avatar
You should've done more reserch before turboing a car....
Stock injectors @ 12psi = motor pieces on road in a couple days.
My fuel pump is still fine.. .450s at 10lbs... you just need injectors and something to control them.
Old Feb 24, 2005 | 05:05 PM
I got a honda's Avatar
weird how you have to add washers?? my tdo4 18g spikes by itself to 14psi stock gsr
Old Feb 25, 2005 | 01:43 PM
CAE's Avatar
CAE
Default Re: greddy td04 kit? (iluvboost)
hey guys,what should i do first get a race built head or work on the block first,thanks guys i appreciate the advice.
Old Feb 25, 2005 | 03:50 PM
PrettyLude's Avatar
work on the bottom end first
Old Mar 1, 2005 | 02:46 PM
CAE's Avatar
CAE
Default Re: (PrettyLude)
ist ok ok to hook the hose from the bov and t it between the fuel regulator and the fmu?thanks please need answer/thanks
Modified by CAE at 4:24 PM 3/2/2005
Old Mar 1, 2005 | 03:20 PM
dustin's Avatar
Default Re: (CAE)
Don't run 12psi on an FMU. Please. Don't run any more than 7psi boost on an FMU.
Old Mar 3, 2005 | 02:40 PM
CAE's Avatar
CAE
Default Re: (dustin)
hey guys is it okay to connect the hose from the bov and t it between the fuel regulator and fmu?thanks
dustin's Avatar
Default Re: (CAE)
It should be fine.
abourmaian
Jan 21, 2008 11:02 AM
avotegra
May 22, 2007 12:31 PM
vangc6780
May 3, 2005 02:05 PM
my93hatch
Apr 30, 2005 07:33 PM
