timing question: pulley
Old Feb 23, 2005 | 07:35 PM
xboostin4funx's Avatar
Default timing question: pulley
this is my first honda motor i am building, so please stick with me..haha i just started to put my motor back together and realized i am missing a pulley off the crank. The timing belt goes around it, i went to the dealer just thinking screw it its out ill just buy a new one and they guy has no clue what he is doing and its the wrong one , anyone know where i get a pulley aftermarket. im use to timing chained motors w/ balance shafts and sprockets. any help will be greatly appreciated its for a b18a1 block witha b16 head if that makes a difference, i dont play on running ac or ps,
Old Feb 23, 2005 | 08:14 PM
hybridsol's Avatar
Default Re: timing question: pulley (xboostin4funx)
Mmm... well there is a sprocket on the crank for the timing belt, not a pulley. I think it's the same (?) for all B series motors.
It won't make a difference what head you are using with the sprocket/timing belt, but you'll need a timing belt for a B18C.
Are you referring to the crank pulley (for the alt and a PS pump)? If so, they are all different for B18C, B18B, and B20 series because of the RPM of the motor- it's sized not to over-speed the accessories. Either a B20 or B18B will work, or you can get an aftermarket crank pulley w/o the harmonic damper insert...
Old Feb 23, 2005 | 08:42 PM
Default Re: timing question: pulley (hybridsol)
i know it was going to b a sprocket sorry, but i wasnt sure if i could rob it off of something else, but as long as they r going to b the same from all b series ill be ok thanx
us31wking
Aug 21, 2014 04:50 AM
suje
14
Feb 22, 2012 04:19 PM
f22a
Jan 9, 2010 06:11 PM
hmtcrxsir
Dec 22, 2009 10:21 AM
sejthewedge
Apr 7, 2009 08:45 PM
