my rotor button wont come off!
Old 07-19-2010, 09:53 AM
lickety_britches's Avatar
Default my rotor button wont come off!
as far as i know you just take the set screw out and it comes off yes? well i took the screw off and its not coming off. i figured it was just jammed so i pried it with a flat head and broke half the button off. am i missing something? i looked up all the how to's i could fine and the set screw was the only thing mentioned but this thing just is not coming off.
Old 07-19-2010, 11:51 AM
adamrich33's Avatar
Default Re: my rotor button wont come off!
try using a good rust breaking oil. tap it from both ends, wiggle it, curse at it and it should pop loose, if not, use extrem caution and take a die grinder with a cut off wheel and cut it loose and do not hit the dist. rotor shaft
Old 07-20-2010, 05:20 PM
well i got it off, but now i replaced it and im getting no spark. im assuming a faulty button. twas bought at advance, could this have something to do with it?
Old 07-20-2010, 07:05 PM
adamrich33's Avatar
is the ignition coil good, did it fire before, and does the new rotor favor the old one?
Old 07-21-2010, 10:46 AM
delsolintegra's Avatar
I had a similar problem with my 98 RS.
Finally got the rotor off with penetrating oil and vice grips.
Chewed it up to get it off.
I had a no start (no cranking) problem also later.
It was the plastic tabs on the clutch pedal arms that press on the clutch interlock switch. The tabs broke and fell to the floor and the interlock switch was not being pressed when you step on the clutch.
The tabs are about $4 each and the top one is a pain to put in.
If ypu see broken pieces of plastic on the floor that's the broken tabs.
Also there is a tab on the brake pedal arm that activates the brake light switch. That also broke and the brake lights stayed on, draining the battery.
Old 07-22-2010, 08:00 AM
the car started before just had a bad miss, but at least it ran, now it wont even turn over. i just ordered a rotor button from honda. i put the old cap back on and still nothing so i figure the rotor button is possibly at fault and is a place to start.
sam0218
04-21-2008 07:53 PM
BlueRex1020
02-04-2007 08:59 PM
ridin98civic
09-07-2006 09:33 AM
lostkoz
03-12-2006 11:02 AM
ringgold
12-12-2004 01:49 AM
Quick Reply: my rotor button wont come off!
