P75 s300 in a GSR?
Old Jul 15, 2010 | 08:38 AM
flipstylez86's Avatar
Icon3 P75 s300 in a GSR?
would this combo be okay? im just sceptical cause its non vtec ecu...but then again it wouldnt matter since the s300 will control everything right?
Old Jul 15, 2010 | 09:03 AM
Josh.JD's Avatar
Default Re: P75 s300 in a GSR?
...What year GSR? I would get a OBD1 p28 with the S300. That ECU is VTEC compatible.
Old Jul 15, 2010 | 04:53 PM
oneslowstd's Avatar
That will work.
Old Jul 15, 2010 | 06:52 PM
its a 95 GSR and okay so i bought the p75 obd1 off this guy which he ran it in two vtec cars...plugged it in, everything worked fine BUT when i tried to ripped it the CEL came on vtec didnt work, we plugged the ecu on the laptop the code was "vtec spool"...my question now is since its an LS/GS ecu non vtec is that why its not working? cause when i got home we plugged in the stock p72 ecu, vtec kicked in just fine
Old Jul 15, 2010 | 07:38 PM
racerteg690's Avatar
U can use the p75. Just get it chipped and tuned for ur set up and ull be set.
Old Jul 15, 2010 | 07:41 PM
the p75 has a hondata s300 in it already.....but when we plugged it in the vtec wasnt kickin and the threw a code "vtec spool"
Old Jul 15, 2010 | 07:47 PM
how is vtec wired in then? check your wiring sounds like a wiring issue. has the check engine light always been on? did it ever hit vtec? **** load of questions but might help
Old Jul 15, 2010 | 07:52 PM
its a stock wiring all we did was plugged in the p75 hondata s300....like I said before......I got home we plugged the stock p72 back in...then it ripped and popped V...but when we plugged the p75...it doesnt do it...and turns on the CEL code for "vtec spool"
DC2tuner86
Jul 22, 2010 05:25 PM
dougk1401
Dec 7, 2009 08:55 AM
technine
Jan 17, 2008 10:43 AM
JDMB20TDA
Mar 18, 2007 11:13 PM
tuckin15s_8315
Sep 28, 2005 09:35 PM
